Macbook pro a1502 emc 2835 bios error
  • Miiuser
    • Oct 2022
    • 16
    Hello when trying to flash bios to the motherboard I get Verification error on address: 0x00000010, Device: 0xFF, Buffer: 0x5A.
    Is there any way to fix this error?
    Also the computer will no longer boot.
  • Miiuser
    • Oct 2022
    • 16
    Re: Macbook pro a1502 emc 2835 bios error
    Any suggestions on how to fix?
    • lilnhan
      • Feb 2023
      I also have the same problem with this winbond chip. The error indicated the programmer didnt write the chip probably. Hence, your bios chip was corrupted. Therefore your computer won't able to turn it on. To fix it, you've to reflash the chip without any verification error. I'm also looking for a solution to reflash the chip without verification error. Did you flash via sam connector?
      • Miiuser
        • Oct 2022
        • 16
        Hello yes i flashed via the sam connector. I was able to flash the bios with no errors and the computer will not boot.
        • lilnhan
          • Feb 2023
          which programmer did you use?
          • Miiuser
            • Oct 2022
            • 16
            i used ch341a.
            Any solutions for this or should i just use the laptop for parts?
            • peste
              • 13924
              • ROMANIA
              Originally posted by Miiuser
              i used ch341a.
              don't use the clip...it gives errors...remove the bios chip from the board before writing or reading...use these programs..
              https://www.badcaps.net/forum/showpo...6&postcount=10
              https://www.badcaps.net/forum/showpo...04&postcount=7
              just for example..
              https://www.youtube.com/watch?v=DWWigscuQDY
              try this... if it doesn't work post the full name and model, EMC, serial number S/N, etc...
              • lilnhan
                • Feb 2023
                just for example..
                I've been using clip on macbook 2011 and 2012. it never give me problem. It's not possible to use clip on macbook 2013-2017. I highly recommend neogrammer over asprogrammer
                • Miiuser
                  • Oct 2022
                  • 16
                  just for example..
                  I use the socket on the motherboard to program the bios chip. I removed the bios from 9 macbook only this one gave me an error.
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • cr4zychriss
                    by cr4zychriss
                    • Rebrand: PC Specialist
                    11-14-2025, 04:04 PM
                  • pirati
                    by pirati
                    10-27-2025, 04:20 PM
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • unionjam
                    MacBook Pro A1502 BIOS lock
                    by unionjam
                    Hi friends,
                    Please could someone help me with my BIOS lock ?
                    I unsoldered MX25L6473E bios chip from 2015 board and read data trought CH341.
                    Now I have bios dump hex.
                    SN: C02R3XZHFVH5
                    Can someone send me working bios please?
                    Thank you so much.
                    Tom....
                    12-11-2023, 01:57 PM
