lenovo thinkpad YOGA 11E BIOS password
  • igragon08
    • Sep 2022
    • 52
    • madrid
    #121
    Hello again badcaps team! In the end I tried modifying the BIOS with autopatch and I managed to create the patched image of my original BIOS, then I tried erasing the original and flashing the patched image to do the password reset according to the steps you have to do in your post of the autopatch manual. Also, now I have some practice and I know how to verify the flashes well and I know when I can have a failure and correct it, and I do all the work correctly, but it turns out that my image patched with the autopath does not work (the LED of the ESC key and the LED of the letter "i" on the THINKPAD sticker at the bottom right of the keyboard remain permanently lit) and it does not start, it remains black screen and does not start. I have tried flashing my original BIOS image again and the PC works correctly, and again I tried flashing the patched image but I have the same error, black screen, fixed LEDs on and black screen without starting. From what I understand, I think there's a problem with the patched image, but I followed the steps and everything turned out fine. Could you review my patched image or fix it if it's not correct?
    I'd appreciate it while I'm unable to read the EC chip.
    Thank you very much.​
    • igragon08
      • Sep 2022
      • 52
      • madrid
      #122
      I've read many posts on your forum looking for information, but I haven't found a solution. I've seen that there's also an option to connect some pins of the Nuvotron ncpe288 chip to GND, shorting the LPC bus between LAD0:3 and GND, but it hasn't worked for me. I've tried it several times, using pins 1, 128, 127, 126, and GND from the LLA-1 17833-1M motherboard schematic, but I haven't been successful. I haven't been able to reset the BIOS password following the steps in the post, as the BIOS option always appears to be locked with a password. I would greatly appreciate it if any of you could provide a solution. We have several Lenovo PCs of this model in our company with the same problem, which we offer to our students without financial resources so they can study. So, if anyone could help me and provide a solution, I would greatly appreciate it.
      Best regards.​
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1355
        • France
        #123
        Best regards.​
        for test try
        • igragon08
          • Sep 2022
          • 52
          • madrid
          #124
          Thank you very much for your help, Maxpower3!!! I tried the image you provided, and the PC won't boot. It freezes (the ESC key LED and the "i" LED on the THINKPAD sticker on the bottom right of the keyboard remain permanently lit). It means a black screen, solid LEDs, and a black screen that won't boot. This is also the case when I tested the jumper between LAD0 and GND on the Nuvotron NPCE288GA0DX chip (I got the same freeze and couldn't boot the PC or enter the BIOS). I reflashed my original BIOS image, and the PC started up perfectly again, with the password back as it was at the very beginning. So, something must be wrong with the patch. It's a shame neither method works, but I appreciate your time and help. Any other ideas to try? If you need any more data or files, just ask me...
          Thanks, Maxpower3.
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1355
            • France
            #125
            Multi test for try
            • igragon08
              • Sep 2022
              • 52
              • madrid
              #126
              Thanks again for your help, Maxpower3! I'm looking at the files you sent me, but I see there are 4 images. Could you tell me how to flash them or which files to flash? Is there an order I should follow? Could you please specify how I should proceed and test them? I'd appreciate it. I'm still learning from all of you, and although I'm beginning to understand some methods by reading the rules and steps in the posts, I still have to gradually learn more from you...
              Thanks, Maxpower3!​
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1355
                • France
                #127
                Thanks, Maxpower3!​
                Test them one by one to see if the image comes. Start with auto patched and no pwd. I don't believe the others.
                • igragon08
                  • Sep 2022
                  • 52
                  • madrid
                  #128
                  Perfect, first of all, thank you so much for continuing to help me, Mxpower3. I really appreciate all your help.
                  I'll explain the entire order of work I've done and the results I've obtained. I've tried each of the images, and in this order:
                  1-> Yoga 11e_Password vss FF AUTO_PATCHED -> PC WON'T boot; black screen and both LEDs on solid
                  2-> Yoga 11e_Password vss FF + Nopwd_Patched -> PC WON'T boot; black screen and both LEDs on solid
                  3-> Yoga 11e_Password vss FF -> PC WON'T boot; black screen and both LEDs on solid, and 4 beeps.
                  4-> Yoga 11e_Password vss invalid -> The PC turns on, the screen displays: 0183: Bad CRC of Security Settings in EFI variable, when you press F1 the BIOS password icon appears differently as if it were a person icon, (before it was like a lock), but it does not enter the BIOS, I try with "1234", "1111", "0000", "Lenovo"... but everything gives an error, not even pressing the ENTER key directly is it able to enter the BIOS; the PC turns off. (attached photo of the image on the screen).​
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1355
                    • France
                    #129
                    Ok thanks for many try
                    Ok FF not work
                    just ff 4 bip weird, others bios mod must be checksum wrong
                    Vss invalid work but with supervisor password
                    I saw a post here about correcting checksums for Insyde BIOS.
                    It's interesting.
                    Maybe it can prevent modified bios with Autopatch from not booting.
                    https://winraid.level1techs.com/uplo...VeyYeI4L5z.pdf
                    https://winraid.level1techs.com/t/gu...ontrol/34762/2
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1355
                      • France
                      #130
                      looking at it would be found there
                      • igragon08
                        • Sep 2022
                        • 52
                        • madrid
                        #131
                        Thank you so much for continuing to help me here, Maxpower3.
                        I skimmed the PDF and the link you posted in the post, and I think it would take me months to understand all that info... hehehehe...
                        I'm still a newbie and I'm just learning, to be honest. That's why I don't really understand what you're showing me. I'll try to read everything little by little to see if I can figure something out. But thank you, really. Anyway, I tried the images you posted in the post, but with both flashed, I get the same problem as always: -> PC WON'T start; black screen and both LEDs lit solid as before. It seems like this motherboard or BIOS is resisting. Too bad. I don't know if there are any more options left to try... but thank you for trying with me and for your patience.
                        • igragon08
                          • Sep 2022
                          • 52
                          • madrid
                          #132
                          By the way, I don't know if it's important, but when I flash my original image with a BIOS password, when I press Enter I can enter the BIOS, but I can't change anything because the supervisor password is enabled in the Password menu. One thing I didn't mention is that the option to set UEFI BIOS options and password at unattended boot is also enabled. Could this help further?
                          Thanks again.​
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1355
                            • France
                            #133
                            Thanks again.
                            retry for test.
                            • igragon08
                              • Sep 2022
                              • 52
                              • madrid
                              #134
                              Hello again, and thank you first of all, Maxpower3, for continuing to help me!
                              As soon as I get home, I'll try this last image you sent me and post the results as soon as possible.
                              Thank you so much!!!​
                              • igragon08
                                • Sep 2022
                                • 52
                                • madrid
                                #135
                                Sorry, Maxpower3, but I tried to download the attached file (Desktop) that you added in the previous post, but I can't download it. When I try to download it, I get an error saying "invalid file specified." Could you check the file or see if there's a problem? Because I can't download it, but I can download the rest of the previous ones...
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1355
                                  • France
                                  #136
                                  yes the link did not work SMDFlea deleted it.​
                                  • igragon08
                                    • Sep 2022
                                    • 52
                                    • madrid
                                    #137
                                    Thanks Maxpower3...!!!
                                    This time the link really works. Tomorrow I'll check the images you provided in the link and comment on the result as soon as possible so you can see it. I'd like to be able to understand all the information you sent me, and I'll read it little by little as I can to see if I can gain more knowledge. In any case, I really appreciate it if you can take the time to run tests and post them to the forum so I can test them out. You guys are really the best. People are talking about it everywhere, and I completely agree. You guys are awesome, and I personally appreciate the help you're offering me. So, thank you very much. As I said, tomorrow, as soon as I can check, I'll comment on the results.
                                    Best regards, thanks!​
                                    • igragon08
                                      • Sep 2022
                                      • 52
                                      • madrid
                                      #138
                                      Hello again, and thanks Maxpower3 for continuing to check and sending me the images for testing.
                                      I flashed the last three images you provided in the link, and all three have the same result as always; (black screen, PC does not start, and the 2 LEDs of the "ESC" key and the "i" letter of the Thinkpad logo are permanently lit and the PC is locked without showing the boot LOGO or entering the BIOS or the errors of "CMOS" battery failure and pressing ESC or F1 or anything at all appear... Then finally I tried to flash my original image and it worked again, it shows the error of bad CMOS checksum or something like that (because of the 3 volt battery I suppose) and the option to press ESC or F1, and the PC starts perfectly as always with the BIOS password as at the beginning... Anyway, I thank you very much again for your time, I would be happy to give good news, it seems that this motherboard is resisting and it's becoming something personal and I want to see it work and unlocked... hehehe... But anyway, for my part, I don't mind trying as many times as necessary if you send me more test images, I have no problem trying 50 times if necessary... hahaha,
                                      I'm still waiting to see if I can try another image or something else.
                                      Thank you very much and best regards!​
                                      • Firshad
                                        • Jun 2025
                                        • 11
                                        • united arab emirates
                                        #139
                                        LLA-1 17833-1M please remove bios password
                                        • Aditya11ttt
                                          Adi
                                          • Feb 2019
                                          • 190
                                          • India
                                          #140
                                          what’s the Sio number ??
                                          NPCE288GA0DX
                                          is it this ??
                                          • to5it0
                                            by to5it0
                                            10-24-2025, 01:35 AM
                                          • RMDUiFT
                                            Should I buy a Lenovo Thinkpad E495 with bios password?
                                            by RMDUiFT
                                            Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                            I have a few questions:
                                            • If I would buy this laptop and have
                                            08-25-2024, 09:00 AM
                                            Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook Yoga Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X1 Titanium Yoga Gen 1 boardview and ThinkPad X1 Titanium Yoga Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-07-2024, 04:10 AM
                                            Lenovo ThinkPad ThinkPad X13 Yoga Gen 2 (Intel) Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad ThinkPad X13 Yoga Gen 2 (Intel) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X13 Yoga Gen 2 (Intel) boardview and ThinkPad X13 Yoga Gen 2 (Intel) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-07-2024, 05:00 AM
