HP 840 G7 password
  • kamkooltech
    replied
    help me remove password
    840 g7
    s/n 5CG1118JBK
    THANKS​
  • josebml
    replied
    Hello, I have an HP 840 G7 that does not display an image, I think the BIOS is damaged, I am attaching files of 16 and 32 mb.
    S/N: 5CG1132WLM
    Motherboard: 6050A3136201
  • techrecycle
    replied
    THANKS I WILL DO
    replied
    Originally posted by techrecycle
    where is EC file located
    How many chips do you see with 8 pins ,read the part number on top of each, do a google search to find what each one is.
  • techrecycle
    replied
  • shiyab
    replied
    hi can someone help me to remove bios password
    sr: 5CG0437YQW
    thanks in advance
    post ec file
  • techrecycle
    replied
    sr: 5CG0437YQW
    thanks in advance
  • vbot
    replied
    HP 840 G7 BIOS files Please S70 or S73
    SN# 5CG0466QX4
    ProdID: 10U64EA#BED
    BuildID: 20WWCMBT601#SBED#DBED
    Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPguhKhkjhk8mE.nA
    Motherboard ID: CAMELLIA-6050A3136201-MB-A01(A1)
    MAC2: X3024A9A48C6C
    Reagrds!
    V.
  • hoaca388
    replied
    Originally posted by pronto
    hi i need bin bios, hp elitebook 840 g7 no working, here old bin main and ec
    SN_5CG1390XLM
    HP EliteBook 840 G7 Notebook PC IDS Base Model
  • pronto
    replied
    SN_5CG1390XLM
  • hoaca388
    replied
    Originally posted by bert-bert
    Hello hoaca388,
    thank you a lot for creating an image, but somehow it does not work. Now I guess it's not the BIOS that is the issue. After flashing the BIOS, the charging LED stayed lit some longer than before and now, and there was some blinking and changing to orange on the charging LED, but after about a minute it went out, and about two minutes later I cut the power, and now it looks like before. I do not have a eDP display connected, but a display via USB-C and this did not lit up at all. I guess it was not the BIOS that was faulty. But it was a try. Or do you think, there is more we can try?
    Nevertheless thank you!
    Check hardware problem.
  • bert-bert
    replied
    CT Number_6JKMK06WYDX7KS
    Serial_5CG040300Z
    Product_8PZ98AV
    Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mE.ye
    Build Id_20WWCMAT601#SABD#DABD
    Hello hoaca388,
  • hoaca388
    replied
    I have a defective 840 G7 and I suspect the BIOS being the issue. UEFITool shows yellow and red lines. I guess this means there is an error.
    I attach the BIOS image. I do not know whether there is a BIOS password, but I would like not having to flash the 16MB chip if it is not necessary.
    Would someone mind fixing the attached BIOS file or even better explaining me how to fix it myself?
    I thank everyone in advance!
    SN# 5CG040300Z
    ProdID 8PZ98AV
    Mainboard: CT:PJSCQ00WBE95J7
    Serial_5CG040300Z
    Product_8PZ98AV
  • bert-bert
    replied
    SN# 5CG040300Z
    ProdID 8PZ98AV
  • ilovehaggis
    replied
    Originally posted by shiyab
    hi flash 16 mb ec
    Thanks very much! It did work!
  • vbot
    replied
    HI, I have HP Sure Start password lock!
    HP 840 G7
    SN# 5CG0466QX4
    ProdID: 10U64EA#BED
    MAC2: X3024A9A48C6C
    Could it be reseted to the default settings?
    Regards!
    V.
  • shiyab
    replied
    Originally posted by ilovehaggis
    Could you please help remove the BIOS password.
    HP 840 G7
    SN# 5CG12111DS
    ProdID 8PZ98AV
    Build ID: 20WWCMDT601#SABU#DABU
    Feature byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEnV.eT
    I have tried writing FF to some sections of the 128 chip as per some YouTube videos, but it didn't work. Thanks for your help! I have attached the original bin dump of both chips.
    hi flash 16 mb ec
  • ilovehaggis
    replied
    HP 840 G7
    SN# 5CG12111DS
    ProdID 8PZ98AV
  • shiyab
    replied
    Originally posted by manjunathadv3003
    HP 830 G7
    SN# 5CG1258BLG
    Prod id 3G1K8EC#ACJ
    BUILD ID: 20WWCMDT601#SACJ#DACJ
    Feature Byte:3X476J6S6b7B7H7M7Q7W7m7saEapaqauawbUbhcAdUdpdqfPguhKhkj4jhk8mEnv.GB
    MAC :48-9E-BD-20-7E-B4
    hi try
  • manjunathadv3003
    replied
    HP 830 G7
    SN# 5CG1258BLG
    Prod id 3G1K8EC#ACJ
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • m1ch43lzm
    Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
    by m1ch43lzm
    Hi everyone
    I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
    Programmer models: XGecu TL866II Plus / T48 / T56 / T76
    Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
    There's also an extra OTP Secu.R...
    09-06-2025, 05:47 PM
  • Nopslide
    by Nopslide
    04-01-2024, 04:27 PM
  • chunhualo
    Please Help unlock bios password for Alienware 13 r1 bios password 7digit service tag
    by chunhualo
    HI I have forgotten my old laptop Alienware 13 r1 bios password .
    Can anyone find the master password for my laptop
    The service tag number is : 2JJVH12
    03-16-2025, 04:13 AM
  • Zain Ahmas
    unlock bios password ADVAN soulmate apn21s.
    by Zain Ahmas
    help me to unlock bios password ADVAN Soulmate board code: apn21s
    11-10-2025, 01:14 AM
