need help with samsung np350v5c bios
  • amr soliman
    • Oct 2015
    • 133
    • egypt
    i need bios for samsung np350v5c-s1eru with black screen
    this is original bios
  • sopik78
    • Nov 2013
    • 520
    • Czech Republic
    Re: need help with samsung np350v5c bios
    https://www.badcaps.net/forum/showthread.php?t=85265
    • amr soliman
      • Oct 2015
      • 133
      • egypt
      sopik78 allready try this but not working
      • peste
        • 13924
        • ROMANIA
        try..
        • amr soliman
          • Oct 2015
          • 133
          • egypt
          peste thank you but still no screen
          • sopik78
            • Nov 2013
            • 520
            • Czech Republic
            Is this the same laptop like in your another thread here https://www.badcaps.net/forum/showthread.php?t=92149
            Try reflash both SPI IC's, this should work, if not, definitely not a BIOS issue
            • amr soliman
              • Oct 2015
              • 133
              • egypt
              sopik78
              thank you very much you are the best
              • Inf1
                • Nov 2018
                • Poland
                sopik78
                Your BIOS is working fine. Thank you very much
                • Kjell
                  Samsung Series 9 - BIOS issue
                  by Kjell
                  After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                  Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                  08-01-2025, 09:15 AM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • cr4zychriss
                  by cr4zychriss
                  • Rebrand: PC Specialist
                  11-14-2025, 04:04 PM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
