need help please samsung np350v5c-s1eru
  • amr soliman
    • Oct 2015
    • 120
    • egypt
    i need bios for samsung np350v5c-s1eru
    power on with blank screen
  • Mazorca
    • Jan 2017
    • 463
    Re: need help please
    Post your BIOS backup, someone will help you, also motherboard model. Read twice, compare, then post.
    • amr soliman
      • Oct 2015
      • 120
      • egypt
      ik thank you
      • sopik78
        • Nov 2013
        • 517
        • Czech Republic
        This might be GPU problem while there is AMD Radeon HD7670..
        Any output on analog VGA, does it read from HDD?
        • amr soliman
          • Oct 2015
          • 120
          • egypt
          i removed the gpu coil to convert from dis to uma same result
          • amr soliman
            • Oct 2015
            • 120
            • egypt
            here is my old file
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • Habble7
              I need a BIOS dump for the Samsung S49CG934SU monitor
              by Habble7
              The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
              Suspected Cause:
              I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • Vesko356
              by Vesko356
              08-11-2023, 03:27 AM
              09-07-2024, 05:50 AM
            • TJ65
              Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
              by TJ65
              i made out of two broken Samsung Galaxy Tabpro S one that works partially.
              The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
              I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
              The problem is, that the micom Version doesn't match with the bios version, see picture.
              How can i update the Micom Version? The Samsung bios update wont work.
              With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
              01-09-2025, 01:35 PM
