Samsung NP350E update BIOS with dead battery
  • outsider
    • Apr 2014
    • 104
    • localhost
    Hello
    Samsung NP350E I need to update the BIOS to the latest version, but I have a dead battery and the application does not release me due to low battery level. Is there any way around it?
    Regards!
    • 22209
    Re: Samsung NP350E update BIOS with dead battery
    Originally posted by outsider
    Hello
    Regards!
    Is your motherboard part number lA-8861p ,if it is you can short pin 5 (+3VL) to pin 6 (gnd) or 7 (gnd) with tweezers on the battery connector during the update.Keep the pins shorted until the bios/micom is updated and the laptop shuts down,then release the tweezers .Go into the bios at startup and check if its been updated,and reset to bios defaults.
    EDIT: Remove the battery first !
    • outsider
      • Apr 2014
      • 104
      • localhost
      SMDFlea
      Thanks for Your replay. Before you wrote back to the post I reprograming BIOS with the programmer.
      For the future, to simulate a connected battery (also in other laptops) I have to short the + 3VL pin with GND on the battery connector?
        • 22209
        SMDFlea
        No not all models. Some bios updates include an *.ini file that can be modified to disable the battery check, or can be forced to update using command line switches /nodate /force ,it all depends on the type of bios.You have to do a little research for each one .
        • pingaroon
          • Nov 2019
          • 121
          • uk
          I discovered the /SKIP_CHECK_POWER command-line switch by running strings (linux) on the manufacturer bios update .exe file and looking for any useful switches. Using this switch successfully bypassed the check (passed through an admin cmd terminal) on an old NP600B5B laptop which otherwise complained instantly at the >30% requirement message. May work on other older Samsung models too... I also found older Samsung models will only play nice for bios updates in a Windows 7 environment. No luck with 10 or later... These bios updates can be critical - in the case above, "SATA Gen 3 Mode Enable" appeared in the updated bios - massive speed difference afterwards...
          • ianbak
            • Apr 2023
            • 62
            Cheers Pingaroon - that option just helped me bypass a battery check!
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • akwky
              by akwky
              Hi!
              04-14-2025, 01:56 PM
            • iZakre
              HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
              by iZakre
              Hello everybody!
              To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
              The thing is that I had installed TeamViewer and could log into the computer...
              02-19-2023, 02:27 PM
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
