HP 15-AU030WM DAG34AMB6D0 REV D W25Q64
  • TyMercer
    Can I flash a working BIOS from one computer to another of the same make, model, etc?
    by TyMercer
    Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
    11-13-2025, 09:39 PM
  • MMH3
    Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
    by MMH3
    i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
    Never ever i experienced problems with that.
    Now i have one 5050sff machine, where this jumper isnt working at all.
    I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
    The history of the machine is that i used it in my office...
    03-23-2025, 09:28 PM
  • DynaxSC
    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
    by DynaxSC
    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
    The board is generally working now, all PCIe ports are working, Windows installs normally.
    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
    03-10-2025, 12:27 PM
  • obelix24
    Macbook Air 2020 (a2179) - touch id not working
    by obelix24
    Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
    I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
    02-09-2025, 12:57 PM
  • hopkok
    Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
    by hopkok
    Hi masters, I need your help.
    I am working on Lenovo Legion 16ITHg6
    Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
    INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
    My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
    AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
    Power LED is not working as well, power button working well.
    UI26 ??? is there any firmware too? Powered by +3VALW_AG.
    Motherboard...
    05-04-2025, 09:35 AM
