dablidmb8eo rev e
  • toyoki
    • Nov 2014
    • 15
    • Algeria
    dablidmb8eo rev e
    hi i need toshiba l50-b-27w psktce-04T00MG4 motherboard dablidmb8e0 rev e i tried all files in forum doesn't work except one screen turn on without display just a horizontal ligne i tried a new screen the same i think because my motherboard have radeon graphic and 5TH G CPU SORRY FOR MY ENGLISH
    file attached is the one with ligne
  • Mazorca
    • Jan 2017
    • 463
    Re: dablidmb8eo rev e
    I cleaned your bios, try it and reply. If you get the same line on left hand upper corner, take out hard drive, try again, I have had bad drives do this and never boot up.
    • toyoki
      • Nov 2014
      • 15
      • Algeria
      thanks for reply but its the same even without drive just lignes on screen and no display at all with hdmi
      • toyoki
        • Nov 2014
        • 15
        • Algeria
        Plz help
        • peste
          • Dec 2016
          • 13924
          • ROMANIA
          Originally posted by toyoki
          Plz help
          is it safe (PSKTCE) ?? .. because the posted bios is ..
          (PSKTNE) ... or did someone change the original bios ???
          • toyoki
            • Nov 2014
            • 15
            • Algeria
            posted bios downloaded from here same motherboard code but mine is PSKTCE
            • peste
              • Dec 2016
              • 13924
              • ROMANIA
              try ... bios extracted from the update on the site Toshiba + DMI and KEYWIN
              • toyoki
                • Nov 2014
                • 15
                • Algeria
                It work fine thank you so much
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
                • smic717394
                  by smic717394
                  07-25-2024, 10:16 AM
                • Chrissygizmo
                  by Chrissygizmo
                  02-10-2025, 12:33 AM
                • spice_disc
                  Vizio TV M50-C1 reboot cycle and static on screen
                  by spice_disc
                  I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                  The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                  09-08-2024, 02:37 PM
