Dablqmb16e0 rev e
  • jacospama
    • Aug 2019
    • 235
    • Ghana
    Dablqmb16e0 rev e
    PLEASE COULD SOME ONE HELP REPAIR THIS DUMP. it doent display but when i press the capslock and nmslock it give signal like a working machine
    • 20619
    Re: Dablqmb16e0 rev e
    Is the Toshiba short part number PSKWNE
    • jacospama
      • Aug 2019
      • 235
      • Ghana
      yes please (PSKWNE-06W04XGR)
      • Mazorca
        • Jan 2017
        • 463
        I have cleaned the ME region of your dump, try and reply please.
        • jacospama
          • Aug 2019
          • 235
          • Ghana
          Thank you Senior.
          but is still not given signal. if i preess the capslock and numslock it appears like a working laptop.it also give black shadow
            ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
            This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-12-2024, 03:28 PM
          • Woodsworth
            PS3 CECHC03 60GB YLOD Troubleshooting
            by Woodsworth
            I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
            START
            Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
            03-19-2024, 07:58 AM
          • CG2
            Janome DC3050 Sewing Machine Pedal Resistance
            by CG2
            OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
            Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
            04-14-2023, 07:53 AM
          • claws77
            FX553VE-DM318T(FX553v) not POSTING
            by claws77
            Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
            Gpu - nvidia geforce 1050ti
            Ssd orion o700
            Hdd hgst721010A9e630
            See images
            What's not working right?
            The system does not even POST, display is black,
            LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
            When did the problem happen?
            My laptop had dual boot setup, ubuntu and windows 10.
            It already had a moklist error, that would occur when i tried to boot ubuntu.
            05-17-2025, 04:09 PM
          • csberti03
            645 G10 with some liquid damage around the bios chip
            by csberti03
            Hi!
            I could use some help.
            I have a 645 G10 with some liquid damage around the bios chip.
            After cleaning, the laptop does the same as in RHS93-s reply above.
            1. F5 key LED lights up Orange
            2. Power LED flashes White/Orange
            3. Machine turns on and off like this a few times
            4. Finally the F5 key LED turns off and the Power LED stays white
            5. If I press power button in such condition I get 7 flashes on the CapsLock LED
            6. Laptop reacts to the power button: if I press it long enough the machine turns off...
            08-28-2024, 04:17 PM
