Re: hp 450 g7 password
Hello my dear friend! I flashed this bios, but when I turn it on, there is an error, and the MPM is locked. And the inclusion is long.
hp 450 g7 password
Okay, at the risk of throwing this thread completely off topic, here's what I've found about the Absolute software:
I reset the security settings in BIOS and wiped the drive with EaseUS Partition Master, as suggested. I then reinstalled Windows 10 with no internet connection. On first start, Absolute software was installed in the Windows folder, I assume by the BIOS. The files were "rpcnetp.exe", "rpcnetp.dll", and "wpbbin.exe", located in the System32 and SysWOW64 folders. "Rpcnetp" also ran as a system service. I stopped the service, and deleted the rpcnetp files (before I found that wpbbin was also an Absolute file), but those files reappeared after a reboot. I then created dummy files (0kb txt files renamed as .exe and .dll) and placed them in the proper locations, after killing the service/running process, and setting the dummy files to read-only. The software did not reactivate after reboot. I then ran Windows Update, and all updates installed without creating the Absolute Software or CTES folders that were installed on first Windows try. It's been running for several hours now without installing the Absolute software or entering "Device Freeze" mode. I haven't tried Windows update without creating the dummy files to disable rpcnetp/wpbbin, so I don't know for sure yet if resetting the Security Defaults in BIOS would have really set Absolute to not install by default, but I will test that in the near future, now that I know how to disable it. I can only assume the software uses the UUID or serial number to check the status, regardless of the persistence module state. I can say that the Device Freeze and Absolute installation does not change the module's inactive state or re-enable it, as the BIOS setting remained permanently disabled even after previous Windows install and Device Freeze. Thanks again for your amazing help with this, and hopefully this info may help anyone dealing with this in the future.Leave a comment:
Hello! Help me please. I saved dump both bioses incorrectly and now I don't have the original bios (they have them but they are corrupted, I will add them to the message). Can you give me both any perfectly working bios with cleared MPMs? Or fix my original bios with password clearing?Attached FilesLeave a comment:
Anyone maybe able to help me take a look at my bios one more time?Leave a comment:
You can try yes, but I don't think it will work out. Your bios should be modified first to activate MPM mode, and then you will be able to make changes with the BCU. I'm talking about disabling Absolute if that's your goal.Last edited by Vesko356; 04-08-2023, 01:59 AM.Leave a comment:
I do not think so. But in order to succeed in what you are aiming for, the machine must be in mpm active mode.Leave a comment:
You can try setting both "Permanent Disable Absolute Persistence Module Set Once" to "Yes" and "Absolute Persistence Module Current State" to "Inactive" at once via BCU then restart and enter the bios to see if it's changes, just go ahead and experiment with different options, if something go wrong you can always reflash Winbond chip and start all over.
Yes.
Can I brick my laptop if I do this? Btw, I successfully obtained the config for my laptop and did what you mentioned. I'm having second thoughts as to setting the config because I was worried I might brick my pc. ThanksLeave a comment:
Didn't realize I can't edit replies. I reflashed the original BIOS and EC, and laptop boots again but with the error same as before(as i would expect).
UghLeave a comment:
Hi, just letting you know I flashed both your files and the laptop now won't boot, the numlock and caps lock flash occasionally and the wireless/micmute stay lit. it will powercycle every 15-30 seconds and repeat. I haven't flashed back the originals yet but both chips verified with your flashesLeave a comment:
I will try this Monday or Tuesday. What is the best way for me to fill in the DMI? Thanks for the speedy response!Leave a comment:
Hi. I was following what people said here and tried unlocking some HP's. So I ran into a problem with one of the laptops, a Probook 450 G7. I thought everyone said it has a 32mb and a 16mb SPI and to onlydo the 16, so I found a chip(25B127DSIG) that was 16MB, I backed it up and then ran the tool, flashed it and the password was gone. But then I had an error for the Security controller. And all the hardware ID's seemed to be gone. I realized looking closer that I had flashed the EC. So i restored the backup image I took but continue get the security controller error, So i found the second SPI(25L12872F?) and dumped that, it looked like what i expected from the BIOS and it actually gave me hardware details so I unlocked that and flashed it back, and then reflashed the EC with it's original backup I took. However while the hardware ID's were fixed, I continue to get security controller errors. After each attempt I have reset security to defaults, entered the code it gives, F1 to clear TPM, and even tried reflashing the BIOS from inside windows, but I continue to get the controller error. Any help would be appreciated.
I have included the "original dumps" although the EC was taken first, i messsed it up, and then backed up the bios, My fear is when I flashed the ec and powered it up, something was changed in the bios chip too and because of that I now have managed to screw up the states between the two and cannot easily get them synchronized again. Im only including the original dumps to try and keep it clean. Hope someone can help
You must fill your DMI manually.Attached FilesLeave a comment:
I have included the "original dumps" although the EC was taken first, i messsed it up, and then backed up the bios, My fear is when I flashed the ec and powered it up, something was changed in the bios chip too and because of that I now have managed to screw up the states between the two and cannot easily get them synchronized again. Im only including the original dumps to try and keep it clean. Hope someone can helpAttached FilesLeave a comment:
Try to reset security settings to default in the bios, then format the disk under Diskpart and reinstall Windows once again. There is no logic for me to reappear again now. Are you sure it's a Absolute or may be it's something else like Windows Autopilot?Last edited by Vesko356; 03-01-2023, 12:16 PM.Leave a comment:
I did wipe and reinstall as soon as the BIOS was set right, but Absolute was forced back in as soon as I did Windows update for drivers. I'll keep playing with it to try to remove it and keep it out. If not, I'll put Linux on it.Leave a comment:
Reinstall Windows, no other option - based on your old bios settings this bloatware is already installed itself on your hard disk, and you should reinstall the operating system to get rid of it once for all.Leave a comment:
Vesko356, you are the f*cking man! After playing around with those settings, the "Current State" setting completely disappeared and BIOS screen reports Permanently Disabled and status Inactive. Now to get rid of the damn Absolute software that forces itself in to the system every time it updates, but I won't clutter up this thread with this anymore. Thanks again!Leave a comment:
Hey guys,
have a laptop here that has a supervisor Password (dump in Attachements).
Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
the laptop works but everytime it wants me to type a supervisor password i never set.
I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
Anyway i wanted to ask what of the two chips is the ec bios because on the left...-
Channel: BIOS Requests ONLY!
by mferna14Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...05-13-2025, 04:16 PM
by Badpatch02Hi all, I'm new here, a few words about myself: CS student, interested in hardware stuff too - tinkering my whole life but with practically no experience when it comes to firmware "hacking".
So I have this X380 Yoga with a supervisor password in place and before doing anything stupid I figured I'd rather ask.
I plan on using the tool from this thread: https://www.badcaps.net/forum/troubl...password-remov...-
by Johnny hHello,
I'm hoping someone can assist me.
I have an Asus Vivobook 16x Pro OLED laptop which has a BIOS password, and I can't seem to find it.
It still boots into Windows (boots from whatever SSD is installed but not from USB).
The model number is M7600R and serial number is N8N0CX03H71131C.
I tried AMITSESetup Decryptor but the password I got doesn't make sense (it's got a line break and special characters).
I also tried to use *************** MOD EDIT ,redacted************** and it also gave me the funny password of
Code:tmNx\'=QJQ
by coolshrimpHere is all the info you should need to remove bios password from your same model or one with an MEC-Chip and also write back the config data
T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
See Diagram for Wiring.
Use MEC-1633#ISP on your RT809h
This is same Jtag pinout and method for T490S/X390
(But your R/W 10K Resistor Location May In a Different Location)
MEC-Chips Store Bios Password In a Secure Un-Editable Area
Following steps clear that secure area to re-initialize itself to default (Blank)
- Loading...
