Bios A315-56-3325
  • husniddin
    • Jan 2017
    • 98
    • Uzbekistan
    Bios A315-56-3325
    Hi guys,
    I need bios laptop Acer A315-56-3325.
    My backup bios.
    Thank you.
  • EbrahimSiami
    Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
    by EbrahimSiami
    I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
    **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
    **What I have tried so far:**
    1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
    07-02-2025, 02:31 PM
  • Wg188
    ACER Veriton Z4660G AIO bios help
    by Wg188
    I have an Acer veriton Z4660G all in one pc,
    Model: Z4660G-I5850H1 (VZ4660G_W)
    Need bios dump and schematic would save my life !
    to make a long story short I bought this all in one used
    with a broken lcd, with the objective of making a custom desktop out of it
    ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
    06-17-2023, 02:20 PM
  • ub6ib969
    Acer Predator PO3-650 BIOS can someone help convert .CAP to .BIN ?
    by ub6ib969
    Model Number: PO3-650
    Part Number: DG.BK4AA.006
    Serial Number : 33400117730
    BIOS IC : XM25QH256C
    I have uploaded the bios from the acer website and the extracted bios from the board. Any help would be appreciated...
    07-02-2025, 03:51 PM
  • zarabota
    Acer Aspire A717-71G - problem BIOS with keyboard
    by zarabota
    I am experiencing the following issue with my laptop. I have an Acer Aspire A717-71G with a motherboard model C5MMH/C7MMH LA-E911P Rev. 1A. Unfortunately, the original board stopped working, so I purchased a replacement. The new board is the same model but a different revision (Rev. 1B). From what I understand, this should not cause compatibility problems.
    However, the replacement board came with a BIOS version intended for the Acer Nitro 5 AN515-51, which causes the keyboard to function incorrectly. I attempted to reflash the BIOS chip using a CH341A programmer...
    09-03-2025, 01:58 AM
  • verniumEN
    Acer Extensa 15 EX215-23-R7NG - BIOS, badly need help :(
    by verniumEN
    My laptop model is EX215-23-R7NG
    BIOS chip XM25QU128C
    Here is my original bin file, as well as how the BIOS chip looks like
    My situation is if I press my laptop power on, fan turns on for the first five seconds and turns off, no display (not even acer), but power indicator is on, and the CPU gets warm, even caught one time if powered on for long (before an hour) the fan turns on again, is it only right that I'm approaching via BIOS?
    Before I got into this situation, I was just watching movies, and while turned on, pressed the battery reset button and cleaned...
    04-21-2025, 02:31 AM
