need to clean me region
  • String2016
    • Nov 2015
    • 2242
    • philippines
    I need help please clean this file it shuts off 30minute and keep restarting
  • Ghamidi
    • Mar 2020
    • 306
    • France
    Re: need to clean me region
    try....
    • String2016
      • Nov 2015
      • 2242
      • philippines
      still the same it shuts off 15min sometimes 20 to 30minutes then keep restarting and once shut down sometimes cannot turn need to rest for a minute to turn on again,this one has a dedicated graphics
      • String2016
        • Nov 2015
        • 2242
        • philippines
        the one above is the bios i got here in this forum but here is the original backup
        • peste
          • 13924
          • ROMANIA
          try..bios extracted from the site update..
          • String2016
            • Nov 2015
            • 2242
            • philippines
            @peste thank you its working
            • Destroyer-Br
              [HELP] ME Region Cleaning Request – Motherboard GK5MP5X 1.0
              by Destroyer-Br
              I’m working on a laptop in which I replaced the PCH, but I’m unable to clean or rebuild the Intel ME region using FIT.
              When I load my dump into FIT, it only shows the Intel(R) ME Kernel section. The full ME region structure does not appear.
              If I manually replace the ME region inside the decomp folder and try to build the image, FIT does generate an outimage.bin, but the file is corrupted.
              After flashing it, the board does not power on — no signs of life.
              I’ve identified that the issue happens because my original dump does not contain a complete or valid ME...
              11-23-2025, 02:48 PM
            • tom3k
              Dell Precision 5540. Need clean ME Region
              by tom3k
              Laptop: Dell Precision 5540
              MB: LA-H331P Rev: 1.0(A00)
              Hi.
              I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
              After extracting my BIOS in FIT the ME Region size is 7565 KB.
              However the ME Region files I fouud online are 11688 KB in size.
              Can someone help me find he correct clean ME Region?
              Thanks!
              Code:
              ║ Family │ CSE ME ║
              06-28-2025, 12:34 PM
            • Adenitz
              Clean ME region - a bit of theory
              by Adenitz
              Hello laptop repair experts,
              can someone plese, help me understand the significance of cleaning ME region in a BIOS dump file?
              I know that Manegement Engine (ME) data is part of BIOS/UEFI firmware. I know that it contains some HW specific data for the particular laptop.
              What I don't know, why do I need to clean ME region if I try BIOS dump file from another laptop (of course same type and model). I'm not sure if this is only because of the serial number (not sure if that is stored in ME region at all).
              Recently, I had a two cases where laptops (one is Lenovo Idepad...
              10-21-2023, 04:44 AM
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
            • Lexsmash85
              Bricked bios from a legion y540-15irh (81sx) . Needing dmi/clean me region maybe
              by Lexsmash85
              Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
              Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
              USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...
              08-06-2025, 03:41 AM
