Issue with trying to dump my Surface Go BIOS with fpt
  • Asianking
    • Dec 2020
    • 7
    • Usa
    Issue with trying to dump my Surface Go BIOS with fpt.
    WS: Surface Go
    OS: Windows 10 Home 64x
    Processor: Intel(R) Pentium(R) CPU 4415Y @ 1.60GHz
    BIOS Version/Date: MS Corp 1.0.28, 6/17/2020
    FPT Version: 9.5.0.1428
    What happen when you run the FPT command?
    I'm getting the error as follow:
    DOS - The program or feature [path] cannot start or run due to incompatibility with 64-bit version of windows. Please contact the software vendor to ask if a 64-bit Windows compatible version is available.
    Windows64 - Error 201: [FPTw64.exe] cannot run on the current plaform. Please contact your vendor.
    What else have you tried?
    Boot to System Recovery and select to troubleshoot then select Command Prompt. Test running fpt and am getting the same error.
  • Asianking
    • Dec 2020
    • 7
    • Usa
    Re: Issue with trying to dump my Surface Go BIOS with fpt
    nvm; found the issue and was able to backed up. Close this post.
    • Guilty_2121
      • Jan 2021
      • 43
      • Türkiye
      how did you fix it? i'm using x64 and get the same error
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • FalconPunch
        Surface Pro X 1876 Bios corrupted
        by FalconPunch
        Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
        Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
        08-09-2025, 03:56 AM
      • shadow666
        Surface Book 3 1899_TOP Rev 2.0 Bios Dump
        by shadow666
        hello
        i need surface book 3 dump bios
        Model : 1899
        MB : 1899_TOP
        Rev 2.0
        Serial : 037248401157
        CPU :Core i7-1035G7
        Dump Bios problem is no power
        Problem is after update windows surface is blue screen after force shutdown , surface won,t turn on
        Regard...
        02-24-2025, 11:01 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • Kjell
        Samsung Series 9 - BIOS issue
        by Kjell
        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
        08-01-2025, 09:15 AM
