Require dump for HP ProBook 6470b (6050A2466401-MB-A03) BIOS
  • yasiel
    • Jan 2019
    • cuba
    Hello greetings I need the bios of this board which is 8mb
  • peste
    • 13924
    • ROMANIA
    Re: NECESITO DUMP PARA HP HP ProBook 6470b (6050A2466401-MB-A03) BIOS
    Originally posted by yasiel
    Hola saludos necesito e
    l bios de esta placa el cual es de 8mb
    post the original bios of the laptop.
    • babarali
      • Jun 2023
      • 20
      • Pakistan
      • babarali
        • Jun 2023
        • 20
        • Pakistan
          • 22286
          Are those a working bios or are you asking for help ?
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • studdy05
            Bricked HP Probook 450 G7 Bios questions
            by studdy05
            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
            Ive got...
            07-08-2025, 09:24 PM
          • haitham sharabati
            by haitham sharabati
            Hello engineers 😀,
            🔧 Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            💀 Problem:😅
            08-07-2025, 04:54 AM
