T490s bios
Re: T490s not image after upgrade bios
try..Attached FilesPremium supporters get full download access and other benefits.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
It only takes 1 minute:
https://www.badcaps.net/settings/subscriptions -
Hi, pls help clear MEAttached FilesPremium supporters get full download access and other benefits.
ME as in ME firmware, you want the ME firmware cleaning ?
Post what the problem is, be specific - black screen, no boot, running slow, password.
Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
.Comment
Lenovo T490s bios need key broad some key not work
hi every one i have lenov ft491/fx390 nm- b981 rev 2.0 problem is keybroad some key not work here is bios file i chang the keybroad also type 20nx-0032us s/n pf-1ccofyAttached FilesPremium supporters get full download access and other benefits.
Re: Lenovo T490s bios need key broad some key not work
N/n pf-1cc0fyAttached FilesPremium supporters get full download access and other benefits.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
Subscribe to support us. It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
please help me fix Lenovo no display
T490s S/N PC1CJKD​Attached FilesPremium supporters get full download access and other benefits.
tryAttached FilesPremium supporters get full download access and other benefits.
hello. can help me.
lenovo t490s nm B891 rev.2
sn. PC1FBGEH
case.
1. power 1 does not display, turn off the power again and then display, but it takes a long time to appear.
2. after entering windows it often gets stuck..
can someone help me​Attached FilesPremium supporters get full download access and other benefits.
Thinkpad T490s No display. Can anyone fix it ? Thank you
Serial number : PC-1C0HPC
TYPE : 20NY-S3DU00
FT491/FX390
NM-B891 REV: 2.0Attached FilesPremium supporters get full download access and other benefits.
hi tryAttached FilesPremium supporters get full download access and other benefits.
Hi, I have ThinkPad T490s No display but keep restart. Maybe bios corrupted.
Serial number: PC-19T8PZ
TYPE: 20NY-S5KP00
MAINBAORD: FT491/FX390 NM-B891 REV: 2.0
Could help to repair the bios file, thanksAttached FilesPremium supporters get full download access and other benefits.
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by iZakreHello everybody!
To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
The thing is that I had installed TeamViewer and could log into the computer... -
by CityminHi all,
S/N : 5RNK9FFT70...-
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
- Loading...
