bios hp DAOAX3MB6C1
  • aliiash
    • Jun 2019
    • 99
    • england
    bios hp DAOAX3MB6C1
    Hi
    I need bios file for HP G62
    DAOAX3MB6C1 - REV: C
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: bios hp DAOAX3MB6C1
    Use search you find many here , if not post your old dump
    • aliiash
      • Jun 2019
      • 99
      • england
      I not put my back up bios file because my laptop show me in logo this massage : serial number is invalid
      product number not found
      • to5it0
        by to5it0
        10-24-2025, 01:35 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • maanee11
        Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
        by maanee11
        Hello Everyone,
        I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
        It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
        In the website, you can only see specs etc.
        I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
        11-08-2025, 04:08 AM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
      • Forest79
        by Forest79
        07-23-2023, 07:39 AM
