Need bios hp fpw50 la-h323p rev: 1.0
  • axus009
    • 17
    • N/A
    #41
    Re: Bios dump Hp 15-dw1083wm FPW50 LA-H323P rev: 3.0 2020-11-12
    Here's your New bios file, it's a virgin bios from HP with your DMI and Windows Key.
    Serial Number: CND10348M0.
    Originally posted by axus009
    Thank you very much friend, I will program with this.
    Thank you very much, this worked . How can I learn to do this process friend? any tutorial that you can recommend me abusing your valuable help.
    • hussaka
      • Jan 2015
      • 154
      • italy
      #42
      Re: Need bios hp fpw50 la-h323p rev: 1.0
      thank you metro
      • Microm
        • Sep 2019
        • 29
        • Perú
        #43
        Hi, i have a hp 15-dw1060la the caps lock is blinking 3 slow and 2 fast
        old Bios
        • hardware1
          • Sep 2021
          • 2949
          • N/A
          #44
          old Bios
          Here's your New BIOS, it's a Virgin BIOS from HP with your DMI and Windows Key.
          Serial Number: CND111F4QG.
          all donations are welcome,
          • faisalhabib
            • Apr 2017
            • 29
            • Bangladesh
            #45
            its my hp laptop old bios, S/n. CND9241NP7
            anyone help me. please rebuild this bios
            no display problem
            MB MODEL LA-h323p
            • laptopbn
              • Jul 2016
              • 72
              • Viet Nam
              #46
              Re: Need bios hp 15s-du0040tx (fpw50 la-h323p )rev: 1.0
              Originally posted by satishkumar
              good thanks sir
              • bomber8596
                • Nov 2018
                • 39
                • Italy
                #47
                i have this hp 15-dw0120nl (i7-8th) with la-h323p rev 1.0 2019-01-04 motherboard, issue: blinking capslock 5 times slow and 3 fast.
                I tryed flashing several dump files in this post but none working.
                I attach my backup file, can someone help me to clean this dump?
                Thanks very well
                • peste
                  • Dec 2016
                  • 13728
                  • ROMANIA
                  #48
                  Originally posted by bomber8596
                  Thanks very well
                  the posted bios is corrupted .. read the bios chip once more, check it with HxD prog and post again..
                  • bomber8596
                    • Nov 2018
                    • 39
                    • Italy
                    #49
                    2nd reading attached
                    thks
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #50
                      thks
                      Same story.
                      Become a Badcaps supporter
                      Thanks to all supporters.
                      • peste
                        • Dec 2016
                        • 13728
                        • ROMANIA
                        #51
                        thks
                        just as corrupt..use the HxD program and make comparisons between the bios copies...for example post #44 and see how the bios should look and compare it with what you sent..make more copies and which are similar send..
                        there are differences between what you sent the first time and the second time..
                        • bomber8596
                          • Nov 2018
                          • 39
                          • Italy
                          #52
                          Third reading
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #53
                            Third reading
                            Finally
                            Use BID 085EF bios.
                            Transfer DMI + Windows key from your dump to the new one using offsets:
                            320000 - 321FFF
                            HP Notebook - 15-dw0120nl bios F.43 Rev.A
                            • odtech
                              • Jul 2023
                              • 52
                              • South Africa
                              #54
                              Hello.
                              Can i get some assistance too please. I have a Hp 15-DW1014ni that has the 3 long 2 short capslock light. I followed the bios cleaning steps posted elsewhere on badcaps but wasn't 100% successful due to bios encryption and i'm still on the 3 long 2 short code.
                              Edit: Just incase it's missed the motherboard is the LA-H325P with Celeron N4020 cpu.
                              Thanks in advance.
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #55
                                Originally posted by odtech
                                Hello.
                                Thanks in advance.
                                6. Extracting BIOS/EC firmware from update packages
                                https://www.badcaps.net/forum/showpo...45&postcount=7
                                [Guide] How to extract ready for programming dump from HP update executable file
                                https://www.badcaps.net/forum/showthread.php?p=1259537
                                Find your BID version and use the offsets shown in post #53 to transfer DMI + Windows key from your dump to the new one.
                                • odtech
                                  • Jul 2023
                                  • 52
                                  • South Africa
                                  #56
                                  Thanks friend.
                                  I will try this tonight. I did start on this route but then i got stuck with locating my bios file so I went off on the cleaning the bios route instead which didn't work.
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #57
                                    Thanks friend.
                                    There's no need to perform cleaning the ME Firmware in the original dump - it'll be much better to use a virgin dump from the manufacturer support site. You already have it extracted in post #53, as I said just find the BID number in your original dump to know which one of the posted files you need to use, transfer the DMI and Windows key and you're good to go.
                                    • odtech
                                      • Jul 2023
                                      • 52
                                      • South Africa
                                      #58
                                      I tried by copying the offsets in post 53 from the original bios to a virgin bios but it didn't work. Caps lock still flashing 3 2.
                                      In the ME cleaning guide they spoke about encryption keys stored in offset 2000 to 4000 that needed to be copied because my bios is apparently encrypted. Should i copy those too or not necessary?
                                        • 22097
                                        The HP signed SMIP is already in the virgin bios. You only need to mess around if you`re cleaning your own bios.As vesko said,its easier just to use the virgin bios. 3.2 blinks is a ram fault, check for loose ram slot pins and resolder them. If that doesn`t work its usually some other hardware problem.
                                        • odtech
                                          • Jul 2023
                                          • 52
                                          • South Africa
                                          #60
                                          I already check all the pins and swapped memory but will do so again just to be more certain. I'm chasing the bios now because some youtubers has had success with resolving 3 2 by re flashing the bios.
                                          The reason I'm sort of convinced it is the bios is the fact that the laptop is basically brand new. It's a elderly man that bought it but didn't finish migrating to the laptop from his desktop then stored the laptop for a few months. When he fired it up it was dead as a door nail. So i'm thinking frozen bios but having no luck yet. I'm about to toss it though because it's not worth the time it being the bottom of the barrel basic celeron machine.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            Today, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
