Need bios hp fpw50 la-h323p rev: 1.0
Re: Need bios hp fpw50 la-h323p rev: 1.0
Hi, i have a hp 15-dw1060la the caps lock is blinking 3 slow and 2 fast
old Bios
Attached Filesif you find these attachements useful please consider making a small donation to the site
Here's your New BIOS, it's a Virgin BIOS from HP with your DMI and Windows Key.
Serial Number: CND111F4QG.Attached Filesif you find these attachements useful please consider making a small donation to the site
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
its my hp laptop old bios, S/n. CND9241NP7
anyone help me. please rebuild this bios
no display problem
MB MODEL LA-h323pAttached Filesif you find these attachements useful please consider making a small donation to the site
i have this hp 15-dw0120nl (i7-8th) with la-h323p rev 1.0 2019-01-04 motherboard, issue: blinking capslock 5 times slow and 3 fast.
I tryed flashing several dump files in this post but none working.
I attach my backup file, can someone help me to clean this dump?
Thanks very wellAttached Filesif you find these attachements useful please consider making a small donation to the site
the posted bios is corrupted .. read the bios chip once more, check it with HxD prog and post again..Hi everyone,
Thanks very wellDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
2nd reading attached
thksAttached Filesif you find these attachements useful please consider making a small donation to the site
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
just as corrupt..use the HxD program and make comparisons between the bios copies...for example post #44 and see how the bios should look and compare it with what you sent..make more copies and which are similar send..
there are differences between what you sent the first time and the second time..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Third readingAttached Filesif you find these attachements useful please consider making a small donation to the site
Finally
Use BID 085EF bios.
Transfer DMI + Windows key from your dump to the new one using offsets:
320000 - 321FFF
HP Notebook - 15-dw0120nl bios F.43 Rev.AAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello.
Can i get some assistance too please. I have a Hp 15-DW1014ni that has the 3 long 2 short capslock light. I followed the bios cleaning steps posted elsewhere on badcaps but wasn't 100% successful due to bios encryption and i'm still on the 3 long 2 short code.
Edit: Just incase it's missed the motherboard is the LA-H325P with Celeron N4020 cpu.
Thanks in advance.Attached Filesif you find these attachements useful please consider making a small donation to the site
6. Extracting BIOS/EC firmware from update packagesHello.
Thanks in advance.
https://www.badcaps.net/forum/showpo...45&postcount=7
[Guide] How to extract ready for programming dump from HP update executable file
https://www.badcaps.net/forum/showthread.php?p=1259537
Find your BID version and use the offsets shown in post #53 to transfer DMI + Windows key from your dump to the new one.
Thanks friend.6. Extracting BIOS/EC firmware from update packages
I will try this tonight. I did start on this route but then i got stuck with locating my bios file so I went off on the cleaning the bios route instead which didn't work.Comment
There's no need to perform cleaning the ME Firmware in the original dump - it'll be much better to use a virgin dump from the manufacturer support site. You already have it extracted in post #53, as I said just find the BID number in your original dump to know which one of the posted files you need to use, transfer the DMI and Windows key and you're good to go.
I tried by copying the offsets in post 53 from the original bios to a virgin bios but it didn't work. Caps lock still flashing 3 2.There's no need to perform cleaning the ME Firmware in the original dump - it'll be much better to use a virgin dump from the manufacturer support site. You already have it extracted in post #53, as I said just find the BID number in your original dump to know which one of the posted files you need to use, transfer the DMI and Windows key and you're good to go.
In the ME cleaning guide they spoke about encryption keys stored in offset 2000 to 4000 that needed to be copied because my bios is apparently encrypted. Should i copy those too or not necessary?Comment
The HP signed SMIP is already in the virgin bios. You only need to mess around if you`re cleaning your own bios.As vesko said,its easier just to use the virgin bios. 3.2 blinks is a ram fault, check for loose ram slot pins and resolder them. If that doesn`t work its usually some other hardware problem.I tried by copying the offsets in post 53 from the original bios to a virgin bios but it didn't work. Caps lock still flashing 3 2.
.Comment
I already check all the pins and swapped memory but will do so again just to be more certain. I'm chasing the bios now because some youtubers has had success with resolving 3 2 by re flashing the bios.The HP signed SMIP is already in the virgin bios. You only need to mess around if you`re cleaning your own bios.As vesko said,its easier just to use the virgin bios. 3.2 blinks is a ram fault, check for loose ram slot pins and resolder them. If that doesn`t work its usually some other hardware problem.
The reason I'm sort of convinced it is the bios is the fact that the laptop is basically brand new. It's a elderly man that bought it but didn't finish migrating to the laptop from his desktop then stored the laptop for a few months. When he fired it up it was dead as a door nail. So i'm thinking frozen bios but having no luck yet. I'm about to toss it though because it's not worth the time it being the bottom of the barrel basic celeron machine.Comment
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
Yesterday, 04:04 PM -
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
