Toshiba Nb250 Bios password
  • lezsimply
    The Wanderer
    • 659
    • Philippines
    Good day. Hi need help removing bios password from Toshiba laptop model NB250-108, part number PLL2PE-00300wen. Or if possible give bios password. I upload stock bios from chip. Thanks!
  • lezsimply
    The Wanderer
    • 659
    • Philippines
    Re: Toshiba Nb250 Bios password
    Anybody can read this bios dump for password? Thanks
    • evserv
      • Jun 2014
      • 364
      • Russia
      Pad J1 under Memory*Slot1
      Remove battery and disconnect the AC-adapter then short the pads with a minimum of 30 sec with a flat-blade screwdriver...
      • alihomee
        • Dec 2012
        • 1598
        • malaysia
        here u go
        • lezsimply
          The Wanderer
          • 659
          • Philippines
          Originally posted by alihomee
          here u go
          Thanks ali, but with that file laptop wont turn on.
          • lezsimply
            The Wanderer
            • 659
            • Philippines
            There's no Pad J1 under memory slot. Thanks
            • lezsimply
              The Wanderer
              • 659
              • Philippines
              anybody?
                • 22279
                Originally posted by lezsimply
                anybody?
                Did you look under the sticker ? - https://www.jaysonjc.com/diy/removin...ook-nb200.html
                • lezsimply
                  The Wanderer
                  • 659
                  • Philippines
                  Originally posted by SMDFlea
                  I already did Sir. Did it about 4 times.
                  PS. forgot to thank evserv for the advice. The jumper was so small I couldn't see it at 1st attempt to peel the sticker. Got curious and removed whole sticker.
