Macbook air 2015
  • laptopcenter
    • Mar 2019
    • 90
    • haifa
    Macbook air 2015
    I have problem with wifi
    Need bios to solved this error
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: Macbook air 2015
    try..
    • Ghamidi
      • Mar 2020
      • 306
      • France
      i have problem with wifi
      need bios to solved this error
      try this file
      • Ghamidi
        • Mar 2020
        • 306
        • France
        if u have same problem
        test the Pin1 PP3V3_WLAN=3.3V of wifi socket J3501
        GOOD LUCK
        • laptopcenter
          • Mar 2019
          • 90
          • haifa
          Thanks for all
          • cr4zychriss
            by cr4zychriss
            • Rebrand: PC Specialist
            11-14-2025, 04:04 PM
          • lucaszmn
            by lucaszmn
            Problem:
            Initial Findings:
            • I concluded that the
            08-12-2025, 03:01 PM
          • AquaMan Ua
            by AquaMan Ua
            05-17-2025, 09:40 AM
          • traxformania
            TONGFANG "GM7TG7P" Bios Password Problem?
            by traxformania
            I tried :
            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
            11-15-2023, 07:32 AM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
