HDD Toshiba mq01abf050 bios
  • utzlol
    • Apr 2020
    • 10
    • Indonesia
    Need Toshiba mq01abf050 bios with serial number G003235C
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: HDD Toshiba mq01abf050 bios
    Why you need "hdd bios" with your serial number?
    If you damaged the eeprom chip or lose original data from this hdd you need a professional tools to recover data from hdd. but is very expensive.
    Your original eeprom data have a decrypt key that is paired with firmware data plates.
    • utzlol
      • Apr 2020
      • 10
      • Indonesia
      Nah, i'm just trying to repair my dead hdd. The data isn't important, i'm just want to make it runs as my external storage. So, it's impossible to repair when the "bios chip" getting failure? I saw other people replace the swap the chip from another same disk.
      • Claudiomfa
        • Nov 2015
        • 455
        • Portugal
        You allways need original hdd file. Without that your hdd is garbage.
        • utzlol
          • Apr 2020
          • 10
          • Indonesia
          Ah, i see. So that i have to buy a normal board and then swap the bios with the original board, right?
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • YvD-Electronics
            Request BIOS files to flash Toshiba C55-A-1TX laptop
            by YvD-Electronics
            I need the BIOS (bin files) to re-flash the BIOS chips on a toshiba laptop.
            Why I am pretty sure I need this to repair?
            1) Power supplies seem OK.
            2) Battery has been replaced, is charging well ... also not the CMOS battery CR2032, also not OK without RAM, or 1 or the 2 RAM modules (RAMS are OK).
            3) Laptop does really rare (seems random things) with the 3 leds (power, net, ...)
            4) In the past, when trying to restart 100 times via power button, it was sometimes succeeding, now no more.
            08-09-2024, 10:05 PM
