Bios dump for Toshiba L775D-10v
  • Michiel
    • Oct 2015
    • 32
    • Netherlands
    Hi guys,
    Since the laptop was doing strange things, powerled on in the night while not on ac power for a couple days until i remove the battery
    and later on no picture anymore so i guss that its a faulty bios
    i tried a other pegatron bios, goes on and off but still no picture, all voltages come up
    This one is with a AMD A6 processor and GPU in the processor
    And a 2mb bin file !! only 1 eeprom
    Toshiba sticker; PSK40E-04602FDU
    Motherboard p/n; 08n1-0n93j00
    Rev.: 2.1
    Thank you all
  • peste
    • Dec 2016
    • 13803
    • ROMANIA
    Re: Bios dump for Toshiba L775D-10v
    Originally posted by Michiel
    Hi guys,
    Rev.: 2.1
    Thank you all
    try..
    • Michiel
      • Oct 2015
      • 32
      • Netherlands
      power led is on but battery led is showing white and orange at the same time, not responding on power button
        • 22168
        Try this bios PSK40E
        • Michiel
          • Oct 2015
          • 32
          • Netherlands
          Yes! thats the one
          i First powered on the laptop and it did not show any picture
          i heard some kind of reset after 10 secs the dvd drive init again
          I turned it off by holding pow button for 7 seconds
          i removed 1 ddr3 memory
          turned it on with pow button and works ok
          added the same ddr3 again and all 4gb is gecognized ok
          works for about 1 hour and turned it back off
          all was working normally
          but after putting it on again no picture anymore
          i compared the old bios files with Winmerge, but they seem to get corrupted
          now i dont get it back to life anymore
          here are the bios dumps after using the laptop; it worked 1 hour with old2.bin
            • 22168
            The only difference is no DMI in the bios i posted and NVAR which won`t be written until the laptop is booted. Ive added the DMI and you can try it,if the problem persists its something else,the bios is good.
            • Michiel
              • Oct 2015
              • 32
              • Netherlands
              I still have problem with the laptop showing no picture
              But it is running now for a couple hours working ok
              And can shutdown it now without problems
              I hope problem is gone now
              When it jams the wifi light stays on
              When it posts ok the wifi led goes off and then on and
              runs ok
              Ive made a picture of the bios , it is showing main and ec bios versions, is this ok because the laptop has only 1 eeprom ?
              • Michiel
                • Oct 2015
                • 32
                • Netherlands
                Found the problem! One of the USB ports 5volt was shorted!!
                • Raziel19935
                  • Aug 2019
                  • 16
                  • República Dominicana
                  mine only show wifi led orange, cpu cooling fan spin, no video xd
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • haitham sharabati
                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                    by haitham sharabati
                    Hello engineers 😀,
                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                    💀 Problem:😅
                    - Device shows “Administrator Password”...
                    08-07-2025, 04:54 AM
                  • DProf.
                    TOSHIBA DYNABOOK T55/AB, PT55ABP-BJA2 BIOS DUMP
                    by DProf.
                    High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
                    Toshiba Dynabook T55/AB, PT55ABP-BJA2
                    MODEL NAME. Satellite L50-D series
                    P[ART NO PS57MN-00600R
                    Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....
                    09-26-2024, 04:30 AM
