Asus X705UAR
  • alderick
    • Jun 2015
    • 77
    • france
    Asus X705UAR
    Hello guys,
    Can you check my dump and correct if possible?
    White LED ok, but no video (no voltage on lot's of psu but maybe it's bios)
  • piszpunta
    • Jan 2019
    • 255
    • poland
    Re: Asus X705UAR
    Originally posted by alderick
    Hello guys,
    try
    • alderick
      • Jun 2015
      • 77
      • france
      Re: Asus X705UAR
      Thank you, but no improvement.
      • piszpunta
        • Jan 2019
        • 255
        • poland
        Re: Asus X705UAR
        try
          • 22029
          Re: Asus X705UAR
          Try this one too .
          • alderick
            • Jun 2015
            • 77
            • france
            Re: Asus X705UAR
            Still dead, thanks anyway
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
            • kodox
              Asus ExpertBook B1400CB Bios Dump Needed
              by kodox
              need original bios dump, original bios has flashed by other technician before me.
              attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
              unit info:
              Model: Asus ExpertBook B1400CBA-0711A1235U
              S/N: R6NXNZ006657238
              CN: 7F6F
              Mainboard Code: B1500CBA R2.1...
              08-16-2025, 12:20 PM
            • kcp0085
              Request BIOS dump for ASUS FA617NS
              by kcp0085
              Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
              I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
              Specs:
              - ASUS TUF FA617NS-A16
              - CPU: AMD Ryzen 7
              - BIOS chip: Winbond W25Q16JVSIQ (2MB)
              If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
              Thanks in advance!
              05-02-2025, 12:52 AM
            • Tamo Neko
              Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
              by Tamo Neko
              I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
              What Happened:
              I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
              • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
              • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
              What I Need:
              • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
              02-12-2025, 11:29 PM
            • Anchar777
              ASUS P1412CE need BIOS DUMP
              by Anchar777
              Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
              06-26-2025, 03:39 AM
