Samsung np300e4a
  • el panke
    • May 2019
    • 78
    • argentina
    Samsung np300e4a
    hi there
    im having some troubles with this laptop (samsung np300e4a)
    so i wanna use another bios file on it just to check if this solve some ramdoms shutdown
    the motherboard has a 4mb bios chip and model: petronas-14(dc) rev 1.4
    heres is my bios dump that i made with ch341A programmer
    tnax to all
  • Bonzas
    • 471
    • Indonesia
    Re: Samsung np300e4a
    Try this
    • el panke
      • May 2019
      • 78
      • argentina
      Originally posted by martha februarini
      Try this
      this file works!, but still doing some ramdon turn offs
      anyways, thanx alot for the file
        • 20781
        Bios version 09QA.
        • String2016
          • Nov 2015
          • 2233
          • philippines
          SAMSUNG np300e4a
          Can someone fix this bios no display problem please
            • 20781
            Re: SAMSUNG np300e4a
            BIOS guides, methods, resources and tools
            https://www.badcaps.net/forum/showthread.php?t=103526
            2. How to clean ME/TXE region https://www.badcaps.net/forum/showpo...41&postcount=3
            6. Finding bios update packages https://www.badcaps.net/forum/showpo...07&postcount=7
            6.1.11. Samsung
            Samsung do not provide bios downloads at their support pages.
            See: ID Samsung bios from dump and download the official update https://www.badcaps.net/forum/showthread.php?t=88206
            • String2016
              • Nov 2015
              • 2233
              • philippines
              Can someone fix above bios please
                • 20781
                If youve read everything at post #6 and gone to the linked threads and read them as well you should have no problem deciding what to do next. I`ll give one more clue, when you open your backup with HxD https://mh-nexus.de/en/hxd/ search for the word revision to find the platform ID ,then read the rest of this thread.
                • Forest79
                  by Forest79
                  However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                  07-23-2023, 07:39 AM
                • maanee11
                  Help to get Lenovo BIOS bin file for Thinkpad T560
                  by maanee11
                  Hello Everyone,
                  I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                  https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                  In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                  05-15-2022, 11:59 AM
                • Sebastian Codrean
                  BIOS file for ASUS F542UN laptop
                  by Sebastian Codrean
                  Hello to all of you! I need help with a BIOS file.
                  The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                  So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                  02-20-2025, 10:25 AM
                • Fr33man
                  BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                  by Fr33man
                  I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                  *Novo button power on
                  *Disconnected internal battery...
                  09-23-2024, 01:16 PM
                • Kazik
                  Samsung NP680Z5E NP670Z5E (mb: NIKE2-15-DC) BIOS file required
                  by Kazik
                  I received Samsung NP680Z5E laptop for repair. It is charging the battery (charging light on, the voltage on the battery confirms the charging process), but the laptop won't switch on. 3.3V present on the BIOS chip. Power switch checked (however the voltage on the switch is just below 1V - I have no clue if this is the right voltage). Cable connection between the power switch/USB logic board and the main motherboard was checked and is OK. I have no schematic or boardview and I'm also not the greatest specialist in motherboard repair.
                  I'm thinking that the NO POWER...
                  10-20-2022, 05:38 PM
