ECS laptop ed20pa2 bios password
  • uvaiz
    • Jan 2014
    • 113
    • saudi arabia
    Hello everyone, help me to remove password from backup,
    model :ED20PA2 V1.1
    P/N:15-XA6-011100
    THANKS
  • AAAC
    • Jan 2020
    • 458
    • Mexico
    Re: ECS laptop ed20pa2 bios password
    Hello, does the code shown on the picture keeps changing on every reboot? I did check part of the code in order to calculate a matching password.
    Can you record a short video starting from the point you power-on computer, until you press the [CONTINUE] option on the picture? I will like to see all the messages.
    • andrew25
      • Feb 2016
      • 223
      • Malawi
      I ALSO HAVE SAME LAptop, did you solve it?
      • AAAC
        • Jan 2020
        • 458
        • Mexico
        @andrew25
        Check if code changes every 3 incorrect passwords, if it remains constant then provide a picture.
        • andrew25
          • Feb 2016
          • 223
          • Malawi
          Originally posted by AAAC
          @andrew25
          the code changes ... but i found it on a paid site which i dont have access *********************
          • AAAC
            • Jan 2020
            • 458
            • Mexico
            Ok, so the code must be changing every 3 incorrect passwords, do the password typing again until you get a new code, take a picture and upload it here, wait for the password.
            What happens if you click CONTINUE after it shows the Setup Notice code? does it allow you to type the password that will match the code? I'm thinking that if a password is to be generated for a particular code, that it may be only valid while there, meaning that if you cycle power the computer, (the password) it may no longer be valid.
            • andrew25
              • Feb 2016
              • 223
              • Malawi
              after 3 incorrect password attempts it displays a challenge code.. then it shows where to put a master password ... let me share you a picture shortly
              • andrew25
                • Feb 2016
                • 223
                • Malawi
                thats the picture after 3 incorrect password attempts
                • AAAC
                  • Jan 2020
                  • 458
                  • Mexico
                  So I guess there's no way to generate the password from the "Setup Notice" code for a later use, meaning that the laptop needs to remain powered-on waiting for the matching password to unlock it.
                  Could you upload a picture that follows that "Setup Notice" screen (after pressing CONTINUE)?
                  • andrew25
                    • Feb 2016
                    • 223
                    • Malawi
                    can you generate for me?
                    • AAAC
                      • Jan 2020
                      • 458
                      • Mexico
                      Surely I can, I just want to prevent a waste of time if the code will be changing.
                      Did you read my last request? To provide a picture of the screen that follows that "Setup Notice" screen (after pressing CONTINUE).
                      • AAAC
                        • Jan 2020
                        • 458
                        • Mexico
                        I have written a little C program to make it easier, as I was previously calculating the passwords literally by hand, as it's a simple algorithm found in this ECS laptop/netbook and also on an HP ClassMate.
                        If you can post a picture of a new code and keep computer powered-on I will be back in about 10 hours, so check the time of this post and add 10 hours.
                        I will also appreciate if you can upload a picture that follows the SETUP NOTICE screen with code.
                        • andrew25
                          • Feb 2016
                          • 223
                          • Malawi
                          i cant keep the pc On for so long, i have just subscribe this thread to get instant notification.... so if you are available just comment so that i can come online too
                          • AAAC
                            • Jan 2020
                            • 458
                            • Mexico
                            There's probably a misunderstanding as to how I intended to do it, but I'm currently Online.
                            Remember to send me a picture of the screen that follows the Setup Notice [CONTINUE] screen.
                            • andrew25
                              • Feb 2016
                              • 223
                              • Malawi
                              here are the screens for the code after 3 wrong password attempts and the screen which follows when i click on "continue"
                              • AAAC
                                • Jan 2020
                                • 458
                                • Mexico
                                Setup Notice
                                [1KANH48Y]
                                password = AOLJIDJ01
                                A - ALFA ( UPPERCASE )
                                O - OSCAR ( UPPERCASE )
                                L - LIMA ( UPPERCASE )
                                J - JULIETT ( UPPERCASE )
                                I - INDIA ( UPPERCASE )
                                D - DELTA ( UPPERCASE )
                                0 - zero ( digit )
                                1 - 1 ( digit )
                                • andrew25
                                  • Feb 2016
                                  • 223
                                  • Malawi
                                  Setup Notice
                                  [1KANH48Y]
                                  0 - zero ( digit )
                                  1 - 1 ( digit )
                                  it worked bro, thank you so much.. God bless you
                                  • falax41
                                    • Jun 2009
                                    • 5
                                    AAAC,
                                    Do you still have the C program that you wrote for the ECS bios? I have a few of them that are from one of my local schools and we are trying to reload them to give them back to some of the students.
                                    • AAAC
                                      • Jan 2020
                                      • 458
                                      • Mexico
                                      @falax41
                                      I still have the C program.
                                      • Tunker
                                        • Apr 2023
                                        • 4
                                        • Russia
                                        Hello, at our school, on one laptop, they put a boot password in the bios (ECS EH20GM laptop) with three unsuccessful password entry attempts, it issues a SETUP NOTICE request with a key, the key changes. Could you give a link where the bios password generation mechanism is described, or describe the generation algorithm, I would try to generate a key. Thanks
                                        • Bloodhoundje
                                          HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                          by Bloodhoundje
                                          I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                          I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                          After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                          I have desoldered the bios chip (GigaDevice...
                                          03-16-2024, 03:12 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • thxd43
                                          Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                                          by thxd43
                                          Hello, first of all, excuse me, I am using the translator, English is not my native language.
                                          I have a Lenovo ideapad 330S - 14IKB laptop.
                                          The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                                          02-23-2023, 08:37 PM
                                        • Nopslide
                                          by Nopslide
                                          04-01-2024, 04:27 PM
                                        • outsider
                                          Panasonic FZ-G1 MK5 - BIOS password returning
                                          by outsider
                                          Hello
                                          I removed the BIOS password thanks to the help of one of the friends of this forum.
                                          https://www.badcaps.net/forum/troubl...61#post3637661
                                          The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                          06-17-2025, 12:51 AM
