Acer One 14 L1401
  • Bonzas
    • 474
    • Indonesia
    Acer One 14 L1401
    Hello...
    Need help working bios for this laptop
    Code Board : NSBW140X MB V1.0
    I need Main Bios U1 and EC bios U3. both of ic was replaced by other. When i read the ic is blank. Bios from acer only bios bios region...
    • 22035
    Re: Acer One 14 L1401
    Whats the part number and size for U3 ,is it 256KB. Here`s a bios dump.
    • Bonzas
      • 474
      • Indonesia
      Yes sir, U3 near ITE size on chip is 256.
      Thank for your bios, i'll try and report
      • Bonzas
        • 474
        • Indonesia
        After flashing with your bios, laptop turn on & fan spinning but no display.
        but ITE really hot, i think i need to check the whole MB again. Thanks your the bios
        • mahmoodjavan
          Banned
          • Mar 2018
          • 584
          • iran
          Tested and ok
          • Bonzas
            • 474
            • Indonesia
            ok, i'll tell when already create telegram account
              • 22035
              Originally posted by mahmoodjavan
              Tested and ok
              Post it here for everyone else.
                • 22035
                Replace the ITE,its shorted.
                • Andyservo
                  • Jun 2013
                  • 152
                  • Indonesia
                  Thank you
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • Lexsmash85
                    Bricked bios from a legion y540-15irh (81sx) . Needing dmi/clean me region maybe
                    by Lexsmash85
                    Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
                    Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
                    USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...
                    08-06-2025, 03:41 AM
                  • ub6ib969
                    Acer Predator PO3-650 BIOS can someone help convert .CAP to .BIN ?
                    by ub6ib969
                    Model Number: PO3-650
                    Part Number: DG.BK4AA.006
                    Serial Number : 33400117730
                    BIOS IC : XM25QH256C
                    I have uploaded the bios from the acer website and the extracted bios from the board. Any help would be appreciated...
                    07-02-2025, 03:51 PM
                  • ebyte64
                    Bios request for Acer P214-52-58CH
                    by ebyte64
                    Good day.
                    I would like to request a bios for the following laptop?
                    Model: Acer P214-52-58CH
                    Model No: N19Q7
                    S/N: NXVLHE0H11204BA27600
                    SNID: 11201936276
                    Symptoms: Laptop powers on but no picture on screen.
                    I have already checked voltages and all is present. I have checked resistance on the coils to see if the chipset or cpu might be shorted. All resistances look normal. I have tried diffrent ram and I have reset the bios. I have also visually inspected the board to see if anything is burnt or if there are any traces of liquid...
                    09-25-2024, 05:59 AM
                  • zarabota
                    Acer Aspire A717-71G - problem BIOS with keyboard
                    by zarabota
                    I am experiencing the following issue with my laptop. I have an Acer Aspire A717-71G with a motherboard model C5MMH/C7MMH LA-E911P Rev. 1A. Unfortunately, the original board stopped working, so I purchased a replacement. The new board is the same model but a different revision (Rev. 1B). From what I understand, this should not cause compatibility problems.
                    However, the replacement board came with a BIOS version intended for the Acer Nitro 5 AN515-51, which causes the keyboard to function incorrectly. I attempted to reflash the BIOS chip using a CH341A programmer...
                    09-03-2025, 01:58 AM
