Hp Envy 14 spectre bios
  • englez
    • Jul 2012
    • 30
    • Serbia
    Envy 14 spectre,motherboard DASPSDMBAC0 REV C,with black screen fixed with this one...
  • Kenzi
    Cannot modify HP Envy 15 ep-00008na BIOS
    by Kenzi
    I'm trying to modify my BIOS to unlock the advanced menus and unlock the processor power limits. The first thing I have tried is reading the BIOS from the laptop and opening it up in amibcp, and changing the advanced menu to User. However, no matter what tiny change I make to the BIOS, when I flash it back to the laptop with a programmer it says there is corruption and the BIOS needs to be recovered.
    I've also tried rolling back the BIOS to an older version. I made the mistake of updating to the latest version and now I cannot even edit the CFG and OC...
    11-09-2023, 05:22 AM
  • mitchw
    HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
    by mitchw
    Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
    After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
    After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
    I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
    04-29-2025, 03:45 PM
  • BlueNitesFire
    I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
    by BlueNitesFire
    So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
    03-08-2025, 03:49 PM
  • Technodoc
    ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
    by Technodoc
    Asus laptop G614JZ-N3012W Rog Strix with i7
    Mainboard G634J-PMV-VGT
    6050A3441302-MB-A01
    2023-02-10
    Power button works okay....power light goes on
    Red "bottom" leds go on
    Charging led works
    Fans do not spin, capslock key does nothing, screen stays black
    I would like to program the bios again, to rule out a corrupted bios.
    However I run into a size error
    The bios chip is a Winbond 25R256JVEN
    Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
    02-24-2025, 04:46 AM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
