lenovo thinkpad P50
  • sonsy
    • Mar 2017
    • 71
    • Serbia
    #61
    Greetings .
    Can someone help me fix the bios on lenovo Thinkpad P50 type 20EQ-S20D00.
    With the original bios, the laptop cannot turn on at all, and does not turn on any lights. With a bios dump from another laptop (same type), everything works normally, the only thing that is problem is a delay in turning on the screen for about 20 seconds after pressing turn on button.
      • 22130
      Originally posted by sonsy
      Greetings .
      Thread merged. Please read the comment above https://www.badcaps.net/forum/troubl...05#post3339405 post the serial number
      • sonsy
        • Mar 2017
        • 71
        • Serbia
        #63
        Sorry, here it is:
        SN: PC-0DQ6KX
        MAC: C85B761F51C7
        type 20EQ-S20D00
        • Markus1741
          • Sep 2020
          • 967
          • N/A
          #64
          Sorry, here it is:
          SN: PC-0DQ6KX
          MAC: C85B761F51C7
          type 20EQ-S20D00
          Try ...
          • sonsy
            • Mar 2017
            • 71
            • Serbia
            #65
            Originally posted by Markus1741
            Try ...
            Thanks for the effort.
            It doesn't work with this bios. it turns on for 3 seconds and then turns off. So every time I press the power button.
              • 22130
              Greetings .
              post a link to or attach the bios that worked with the delay
              • sonsy
                • Mar 2017
                • 71
                • Serbia
                #67
                Thanks!
                • Markus1741
                  • Sep 2020
                  • 967
                  • N/A
                  #68
                  Thanks!
                  Okay your file ME Region clean ...
                  • sonsy
                    • Mar 2017
                    • 71
                    • Serbia
                    #69
                    still the same as last time, it turns on, lights up, and turns off after 3 seconds.
                    • mariusdumi
                      • Sep 2025
                      • 7
                      • Italia
                      #70
                      Hi, I have a ThinkPad P50 I bought used on eBay, with an invoice from the seller. The seller doesn't know the password, and I need to remove the BIOS password. I have the CH341 flasher purchased from Amazon along with the 8-pin clamp. Can you tell me how to extract the BIOS and then decrypt it?
                      I also need to identify the correct chip to read.
                      MB model: bp500 nm-a451 rev 1
                      Thank you for your attention
                      • peste
                        peste commented
                        Editing a comment
                        post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                    • danito
                      • Jun 2016
                      • 1175
                      • Romania
                      #71
                      you have everything you need here:
                      https://www.badcaps.net/forum/troubl...ssword-removal
                      • DanielCZ
                        • Nov 2025
                        • 3
                        • Česká Republika
                        #72
                        I need help removing the Supervisor Password from a Lenovo ThinkPad P50.
                        **Laptop information:**
                        - Model: Lenovo ThinkPad P50
                        - Motherboard: BP500 NM-A451 Rev. 1.0
                        - BIOS chip: Winbond W25Q128BV (16MB, SOIC8)
                        - BIOS dump size: 16,777,216 bytes (exactly 16 MB)
                        **What I did:**
                        1. I successfully read the original BIOS using a CH341A programmer with a SOIC8 clip.
                        2. I used lenovo_autopatcher 0.2 to create a patched BIOS.
                        3. I successfully uploaded the patched BIOS to the chip (verified using NeoProgrammer).
                        4. The laptop turns on, but nothing is displayed on the screen
                        **Current behavior:**
                        - Power LED is on (green)
                        - LEDs on the keyboard are flashing (NumLock, CapsLock, Mute, Speaker)
                        - Fans spin for a few seconds, stop, then spin again after 30 seconds
                        - Fans run for about a minute, then stop
                        - No display output (black screen)
                        - No POST beeps
                        **What I've tried:**
                        - Waited 5+ minutes for boot
                        - Checked all connections (RAM, LCD cable, SSD)
                        - All components are connected correctly
                        - Wi-Fi card is NOT installed (missing)
                        **Question:**
                        Can a missing Wi-Fi card prevent a patched BIOS from booting?
                        Or is there a problem with the autopatcher for this particular model?
                        I have the original BIOS dump backed up and can restore it if necessary.
                        Could someone please help me:
                        1. Create a working patched BIOS for this model, OR
                        2. Advise what might be causing the boot failure
                        **Attached files:**
                        - original_bios_locked.bin (16,777,216 bytes)
                        Thank you very much for your help!
                        • peste
                          peste commented
                          Editing a comment
                      • Markus1741
                        • Sep 2020
                        • 967
                        • N/A
                        #73
                        Hello you can try this new build file ...
                        In your original file is this error in UEFI Tool 72 ...
                        FfsParser::checkProtectedRanges: Phoenix protected range [A30000h:E70000h] hash mismatch, opened image may refuse to boot
                        That could be a possible error; unfortunately, I don't know for sure either.
                        It doesn't appear in my new file.
                        Just try it; there's not much else you can do unless someone else has a suggestion.
                        • lucaszmn
                          by lucaszmn
                          Problem:
                          Initial Findings:
                          • I concluded that the
                          08-12-2025, 03:01 PM
                        • to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                          by to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                          I have opened the laptop and identified the main BIOS chip...
                          10-24-2025, 01:35 AM
                        • 1g0r
                          Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                          by 1g0r
                          First, the data in brief:
                          Manufacturer: Lenovo
                          Model: ThinkPad L15 G3 21C3-0016GE
                          motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                          IC Bios 1: MX77L25650F
                          IC Bios 2​: MX25L25673G
                          EC Chip: NPCX997KAABX
                          So far I've been a silent reader, but now I need your help
                          I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                          I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                          The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                          01-18-2025, 02:39 AM
                        • MaxonDomkrat
                          Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                          by MaxonDomkrat
                          Hi everyone.
                          I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                          07-30-2025, 01:27 PM
                        • akwky
                          by akwky
                          Hi!
                          04-14-2025, 01:56 PM
