cg70a nm-a671 rev1 bios Pls help this file
  • njugen@gmail.com
    • Apr 2019
    • kenya
    Pls help this file
  • peste
    • 13924
    • ROMANIA
    Re: cg70a nm-a671 rev1 bios Pls help this file
    Pls help this file
    post the original bios and the full name and model of the laptop.
    • to5it0
      by to5it0
      10-24-2025, 01:35 AM
    • maanee11
      Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
      by maanee11
      Hello Everyone,
      I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
      It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
      In the website, you can only see specs etc.
      I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
      11-08-2025, 04:08 AM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • Forest79
      by Forest79
      07-23-2023, 07:39 AM
    • maanee11
      Help to get Lenovo BIOS bin file for Thinkpad T560
      by maanee11
      Hello Everyone,
      I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
      https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
      In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
      05-15-2022, 11:59 AM
