HP EliteBook 820 G1 Bios
  • Genova
    • Jan 2020
    • 116
    • FRANCE
    #41
    Re: Hp 820 g1
    Nobody can help on this ?
    • peste
      • Dec 2016
      • 13335
      • ROMANIA
      #42
      Re: Hp 820 g1
      remove the bios chip before reading from the motherboard and solder on the programmer if you do not have an adapter ..maybe the bios chip is defective ..
      • Genova
        • Jan 2020
        • 116
        • FRANCE
        #43
        Re: Hp 820 g1
        already desoldering and reprogramming same problem? Even with new chip same problem
        • lapfix
          • Mar 2020
          • 2756
          • my workshop
          #44
          Re: Hp 820 g1
          Maybe you destroy a small cap/resistor near bios pads , try to verify at another motherboard or search HD picture to confirm.
          • Lornet
            • Mar 2021
            • 27
            • France
            #45
            Re: HP EliteBook 820 G1 Bios
            Thank you first for all the informations and services offered on the site.
            I have to unlock a HP 820 G1 (bios locked). It would seem, to make a correct bios dump, that it is necessary, on this model, either desolder the eeprom, or solder wires to it (and dump for only the eeprom, not eeprom + EC). Am I right ? I do not know these technics: would you have a solution that would only require a simple clip? Do you need to use any particular software and, if so, which one ?
            Thanks for rour reply and best regards.
            • peste
              • Dec 2016
              • 13335
              • ROMANIA
              #46
              Originally posted by Lornet
              you will need an SPI programmer.
              https://www.youtube.com/watch?v=DWWigscuQDY
              • Lornet
                • Mar 2021
                • 27
                • France
                #47
                Yes, of course. But I want to know if, for unlocking a bios password, I must make dump(s) of only the eeprom or eeprom AND EC ? And about making the bios dump, must I desoldier it (never do it before) or can I use a clip + ch341A + flashrom or ch341a software or another programmer software (which one in this case) ?
                Thanks for your reply and best regards
                • peste
                  • Dec 2016
                  • 13335
                  • ROMANIA
                  #48
                  you only need to remove the contents from the bios chip, it is good to remove the chip from the motherboard, and solder it on the programmer if you have ch341A,
                  and you do not have an adapter for bios chips ..
                  you can soder wires between the programmer and the chip bios on the motherboard,
                  if you can't remove it..do not use the clip because you will have errors..
                  don't forget to make a bios copy before writing the bios chip..if you have CH341A use one of these two programs ..
                  https://www.badcaps.net/forum/showpo...6&postcount=10
                  https://www.badcaps.net/forum/showpo...04&postcount=7
                  • kamalkharbanda
                    • Jun 2013
                    • 91
                    • India
                    #49
                    Hi, I have 820 G1 [2pcs] laptops. Both laptops had delay display problem due to bad me region. I flashed bios with clean me . Now display comes in 2-3 seconds. But shows error
                    Warning Machine is not in committed State.
                    Can anybody help me to get rid of this error ??
                    Thanks in Advance
                    • peste
                      • Dec 2016
                      • 13335
                      • ROMANIA
                      #50
                      Thanks in Advance
                      try this
                      https://www.youtube.com/watch?v=DwcWzGCoj9A
                      • mberbouch
                        • May 2014
                        • 109
                        • Morocco
                        #51
                        Re: HP 820-g1 bios flashed bootup late
                        Try this 16mb main bios with clean me.
                        Thank you very much.
                        • recep1982
                          • Aug 2014
                          • 91
                          • istanbul
                          #52
                          pls help me bios password clear
                            • 21582
                            Doesn`t RCUnlocker or HPUnlocker work ? https://www.badcaps.net/forum/showpo...42&postcount=4
                            • recep1982
                              • Aug 2014
                              • 91
                              • istanbul
                              #54
                              Re: Hp 820 g1
                              thank you frend Haşere Bro
                              • alkuentrus
                                • Aug 2012
                                • 28
                                • Portugal
                                #55
                                HP 820 G1 Bios needed
                                Dear members, I need a working bin for model HP820 G1 (25Q128LF).
                                Serial: CNU421BLJD
                                Product: D7V73AV
                                Its not a problem of password. Its a bios corruption problem.
                                Can I use a bios from other models like 820 G2?
                                Best regards
                                David Inácio
                                • Vesko356
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #56
                                  Re: HP 820 G1 Bios needed
                                  Serial: CNU421BLJD
                                  Product: D7V73AV
                                  Best regards
                                  David Inácio
                                  Upload your dump here.
                                  No.
                                  Become a Badcaps supporter
                                  Thanks to all supporters.​
                                  • alkuentrus
                                    • Aug 2012
                                    • 28
                                    • Portugal
                                    #57
                                    Here it goes.
                                    • alkuentrus
                                      • Aug 2012
                                      • 28
                                      • Portugal
                                      #58
                                      I have been studying this and I wonder if maybe it as ME problem? Computer doesn't boot at all.
                                      • alkuentrus
                                        • Aug 2012
                                        • 28
                                        • Portugal
                                        #59
                                        Any ideas?
                                        • alkuentrus
                                          • Aug 2012
                                          • 28
                                          • Portugal
                                          #60
                                          if i pair these two i got online, should it work?
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • Wutru
                                            HP Elitebook 820 G4 BIOS repair assistance required
                                            by Wutru
                                            Hi guys,
                                            If someone would be able to provide some expertise, I'd be very grateful.
                                            BIOS Corruption - Cause
                                            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                            09-06-2025, 10:32 AM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • lap-top123
                                            Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
                                            by lap-top123
                                            HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
                                            Hp Elitebook 850 G8
                                            ProdID 52W98EC#ABD
                                            SN# 5CG1458XQ7
                                            Mac-address #1: 84:14:4D:2C:4B:5B
                                            UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
                                            Mainboard : 6050A3216701-MB-A01(A1)
                                            08-20-2025, 07:28 AM
