430 g6 DA0X8IMB8E0 rev E BIOS DUMP
  • peste
    • 13768
    • ROMANIA
    Originally posted by branen890
    Hi, i have question will I be able to unlock BIOS on Hp Probook 430 G6 with CH341A EEPROM Programmer + SOP8?
    with the programmer you just read and write the bios...
    post S/N, full name and model, motherboard model, product number,etc.
    The bios chip must be unsoldered from the board before writing or reading..
    do not use the clip, you may have errors..if you do not have anything to unsolder it with,
    solder wires between the programmer and the bios chip..
    you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
    • niggi
      • May 2016
      • 209
      • UAE
      Originally posted by peste
      Re: 430 g6 DA0X8IMB8E0 rev E BIOS DUMP
      try..
      good working
      • questore
        • Dec 2015
        • 573
        • csongrád
        Anybody knows the EC read configuration from schematic OR has an EC dump?
        • laptopgreen
          • Aug 2017
          • 30
          • VN
          Hello, Can u help me build this bios, mainboard no display. Bios aboe ok but no sound.
          HP Probook 430G6
          SN# JPH010C9LL
          DA0X8IMB8E0 REV:E
          Model X8I.
          Thanks!!!!!!!!!
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • studdy05
            Bricked HP Probook 450 G7 Bios questions
            by studdy05
            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
            Ive got...
            07-08-2025, 09:24 PM
          • haitham sharabati
            by haitham sharabati
            Hello engineers 😀,
            🔧 Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            💀 Problem:😅
            08-07-2025, 04:54 AM
