bios dump for hp 15k113nl
  • nassih
    • Oct 2015
    • 282
    • morocco
    hello i need bios dump for hp 15k113nl motherboard day31amb6c0 rev c.pleas
    i have 2 led blinks on caps lock and black screen
    tanks
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    Re: bios dump for hp 15k113nl
    DAY31AMB6CO REV C
    • nassih
      • Oct 2015
      • 282
      • morocco
      ok sir i try and tell u
      tank u very much
      • nassih
        • Oct 2015
        • 282
        • morocco
        ok sir tanks for help i try and trell you
        tank you sow much
        • qayyum786
          • Aug 2018
          • 1959
          • INDIA
          Well Comw bro
          • nassih
            • Oct 2015
            • 282
            • morocco
            hi mr qayyum! tank you bro my problem is solved
            se you brother
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • haitham sharabati
              by haitham sharabati
              Hello engineers 😀,
              🔧 Device Info:
              - Model: HP 15-da2007ne
              - Product Number: 8XF55EA#ABV
              - Serial Number: CND0338P0D
              - CPU: Intel Celeron N4000
              💀 Problem:😅
              08-07-2025, 04:54 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
