Surface 4 Pro BIOS locked
Re: Surface 4 Pro BIOS locked
I've already tried to do that.
I changed single bits from 3f to 3c.
There is still a password.
I can't take it.
Can someone help
Can you share your modifications to the file?Comment
Last edited by SMDFlea; 03-25-2023, 06:39 AM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
All help here is given for free, you are welcome to make a donation to badcaps
https://www.badcaps.net/index.php?pageid=donate1Comment
I have a Surface Pro 4 that has UEFI Bios password. I am confused reading the posts. Can I get a dump of the bios via FPT or do I need to desolder the chip to get a dump file?Comment
https://www.badcaps.net/forum/showpo...0&postcount=42
Wasnt this clear enough?Comment
Unlocked!Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello
Today i have more test to the Surface, and i noticed a couple issues.
First when I'm in the Uefi configuration, the touch doesn't work.
Secondly, in Windows the touch isn't quite responsive, and the right half of the screen doesn't work at all.
I don't know is bios issue or touch issue.
Let me know if you have any other suggestions.
Thanks againComment
Removing the password is not related to the problem. In this model, when the BIOS is not the original you will have problems mainly with the touch.Hello
Thanks againComment
Hello
the bios is the original one . I make a dump from the original bios chip.
I guess my screen its have some problems.Comment
by FalconPunchHello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...-
Channel: BIOS Requests ONLY!
by HighSkaiHi, can someone help me with unlocking the bios password on my bios locked Microsoft Surface Laptop 5
Surface Laptop 5 - 15 in. i7/16/256
Serial number:
0F01D7E23283FB
Thanks!-
Hi guys! So i bought a used Surface Go 2 and it came with a password locked bios.I really wanna remove the lock because they disabled USB booting and disabled SD card which is really weird. I read the forums about the ME tools and fptw but i just cant find one that works for my version of ME. Thanks in advance!
Intel ME Version: v11.8, Build 4494, Hotfix 94
Product Name: Surface Go 2
Product Version: 1
Product Serial Number: 023875311051
UUID: {5C754E9E-0971-4B86-9221-C7D877AED9CD}
SKU Number: Surface_Go_2_1927
Family: Surface...-
by muhuruuHey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
- Loading...
