Surface 4 Pro BIOS locked
Re: surface pro efi password
Try this.Attached FilesComment
Reflashed Surface Pro 4 BIOS to remove UEFI password. Now it boots SLOW
I have a Surface Pro 4 that was UEFI locked.
It worked normally, but you just couldn't get into BIOS without a password.
I stole the BIOS from another identical board and flashed it. I didn't edit the BIOS at all.
Now when I turn it on it takes 30 seconds to get Surface logo (before I flashed it took 1 second)
Then it takes about 15 seconds before you get the Windows 10 spinning dots. (normally it's almost immediate)
Once it's booted into Windows 10 it runs normally. I have also tried a fresh install of Win 10 since the BIOS flash.
I am not very experienced with BIOS flashing. Was there something I needed to edit in the donor BIOS to make this work correctly? Clear ME?Comment
Re: Reflashed Surface Pro 4 BIOS to remove UEFI password. Now it boots SLOW
You should upload original locked bios, get it unlocked and flash that.Comment
Re: Surface Pro 4 - UEFI password removal please?
try...Last edited by SMDFlea; 03-25-2023, 06:39 AM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
No, it's still locked.
I have a clean ME dump for this BIOS. Would that help?
I can't use the clean ME BIOS directly though, because it makes the touch screen stop working. There must be something in the original BIOS that allows touch to function... I somehow need to combine them I think.Comment
YES! Thank you.
Touch works, starts up fast, and no more BIOS password.
Can you tell me how you did it?
EDIT: I ran it though hex compare. The only difference between the two files are a single character at offset 00606620. Is that all it takes?Last edited by mattpd; 02-21-2020, 12:42 PM.Comment
Yes, that's all it takes. The tricky part is knowing the exact byte to modify
Last edited by Vesko356; 02-21-2020, 06:48 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
by FalconPunchHello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...-
Channel: BIOS Requests ONLY!
by HighSkaiHi, can someone help me with unlocking the bios password on my bios locked Microsoft Surface Laptop 5
Surface Laptop 5 - 15 in. i7/16/256
Serial number:
0F01D7E23283FB
Thanks!​-
Hi guys! So i bought a used Surface Go 2 and it came with a password locked bios.I really wanna remove the lock because they disabled USB booting and disabled SD card which is really weird. I read the forums about the ME tools and fptw but i just cant find one that works for my version of ME. Thanks in advance!
Intel ME Version: v11.8, Build 4494, Hotfix 94
Product Name: Surface Go 2
Product Version: 1
Product Serial Number: 023875311051
UUID: {5C754E9E-0971-4B86-9221-C7D877AED9CD}
SKU Number: Surface_Go_2_1927
Family: Surface​...-
by muhuruuHey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-06-2024, 08:10 PM
- Loading...
