Surface 4 Pro BIOS locked
  • surface4
    • Switzerland
    Surface 4 Pro UEFI Password - How to Remove?
    Hello there, i have a surface 4 pro with forgotten uefi Password. How can i remove it? I'm a noob at this point so please explain (also directly on PN possible) what to do. ive read some threads here and now tried to extract a dump of my bios with Intel fpt but with no success (Error 316). I also tried the hibernate trick with no success.
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      Re: Surface 4 Pro UEFI Password - How to Remove?
      You have a bin file 16mb?if yes post here i try remove.
      • alihomee
        • Dec 2012
        • 1575
        • malaysia
        surface pro 4 password
        need help to remove password orignal file is attached
        • alihomee
          • Dec 2012
          • 1575
          • malaysia
          Re: surface pro 4 password
          waiting
          • bachir2004
            • Feb 2015
            • 437
            • maroc
            Originally posted by alihomee
            waiting
            here is your dump with clean bios.but i am not sure if it wil keep the motherbord serial,uuid..
            • alihomee
              • Dec 2012
              • 1575
              • malaysia
              #26
              thanks i will post results after try
              • reverendalc
                • Jul 2016
                • 81
                Originally posted by zaleon
                Hi, thanks for your reply. I have tried without the -BIOS before and it complained it couldn't read that flash area or something to that affect.
                I believe after writing to another member here with the same issue, that iamromroni is correct and the only way to get the full dump is to open up the tablet and read it using a physical programmer.
                However, the Surface Pro 4 from what I've read is extremely difficult and time-consuming to get into without damaging it, so I'm not willing to go that far as long as my Windows is still working. I appreciate your assistance in trying to resolve this issue. This is a great forum!
                did you ever get anywhere with this?
                not only do you have to open the surface (which is a chore), but you have to remove the chip because it's WSON style and cannot be connected in situ.
                at any rate, I have a cleaned dump for surface pro 4 from a previous job, and i'm currently trying to find a way (using software) to flash this clean dump instead of opening this one up and pulling the chip.
                FWIW, using the ROL securebootdebug policy, i've been able to launch an EFI shell. i can't seem to figure a way to flash the eeprom from the EFI shell, and MS doesn't offer an EFI firmware update utility like many other vendors do.
                This isn't Monaco... This is Baghdad
                • zaleon
                  • Dec 2017
                  • 5
                  • US
                  #28
                  Re: Microsoft Surface Pro 4 UEFI Unlock Request
                  No, I never got anywhere with it as far as unlocking the BIOS. Other than that it worked fine in Windows, but I ended up not using it very much and sold it to someone else on eBay.
                  The BIOS is pretty limited in settings you can adjust anyway on those devices. So you aren't missing much even if you are locked out of it, basically just secure boot. I think if I get another device in the future it will be a regular laptop.
                  • reeza_plus
                    • Aug 2015
                    • 55
                    • canada
                    #29
                    hi if i send my bios can you unlock?
                    • wile
                      • Sep 2018
                      • kenya
                      #30
                      Re: Microsoft Surface Pro 4 UEFI Password Request
                      hellow friend , i have an isue with my surface pro 4 wich i did format all the partition and now it wont boot to any system neither will it boot from a pen drive but insted goes to the uefi wich is protected with a password i dont know, any help plz
                      • eknsibby
                        • Nov 2018
                        • 9
                        has anyone had luck unlocking the bios dump?
                        • eknsibby
                          • Nov 2018
                          • 9
                          Hey I have a dump of my bios which is uefi locked. Can anyone help me?
                          • eknsibby
                            • Nov 2018
                            • 9
                            Surface pro 4 UEFI Reset
                            Does anyone have knowledge in how to clean a bios dump?
                            • alihomee
                              • Dec 2012
                              • 1575
                              • malaysia
                              #34
                              microsoft surface pro 4
                              need to remove efi password
                              • alihomee
                                • Dec 2012
                                • 1575
                                • malaysia
                                #35
                                Re: microsoft surface pro 4
                                anyone can help?
                                • alihomee
                                  • Dec 2012
                                  • 1575
                                  • malaysia
                                  #36
                                  still waiting
                                  • alihomee
                                    • Dec 2012
                                    • 1575
                                    • malaysia
                                    #37
                                    can anyone help regarding this
                                      • 20933
                                      try this one.
                                      • alihomee
                                        • Dec 2012
                                        • 1575
                                        • malaysia
                                        #39
                                        no luck it still showing same ....uefi setting locked with password
                                        • alihomee
                                          • Dec 2012
                                          • 1575
                                          • malaysia
                                          #40
                                          anyone can help
                                          • HighSkai
                                            Surface Laptop 5 Locked Bios Password
                                            by HighSkai
                                            Hi, can someone help me with unlocking the bios password on my bios locked Microsoft Surface Laptop 5
                                            Surface Laptop 5 - 15 in. i7/16/256
                                            Serial number:
                                            0F01D7E23283FB
                                            Thanks!​
                                            06-30-2024, 01:53 PM
                                          • Cosmin Adrian
                                            Surface go 2 locked bios
                                            by Cosmin Adrian
                                            Hi guys! So i bought a used Surface Go 2 and it came with a password locked bios.I really wanna remove the lock because they disabled USB booting and disabled SD card which is really weird. I read the forums about the ME tools and fptw but i just cant find one that works for my version of ME. Thanks in advance!
                                            Intel ME Version: v11.8, Build 4494, Hotfix 94
                                            Product Name: Surface Go 2
                                            Product Version: 1
                                            Product Serial Number: 023875311051
                                            UUID: {5C754E9E-0971-4B86-9221-C7D877AED9CD}
                                            SKU Number: Surface_Go_2_1927
                                            Family: Surface​...
                                            03-03-2024, 12:48 PM
                                          • muhuruu
                                            Surface pro 4 bios request
                                            by muhuruu
                                            Hey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
                                            01-22-2024, 05:38 AM
                                          • dr_crx
                                            Dell 7740 Bios locked J3JSD43-8FC8
                                            by dr_crx
                                            Hello i need help please
                                            i have DELL 7740 ST: J3JSD43-8FC8
                                            i tried to read bios bit i think it is wrong because the size of the file is around 1mb
                                            anyone can help to show its location on motherboard please.
                                            i attached the results file the IC i read is : winbond 25q80dvsig
                                            i don't know if its the needed bios or another bios on the motherboard.
                                            thank you in advanced for your help...
                                            07-11-2025, 12:22 AM
                                            Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-06-2024, 08:10 PM
