I have cleaned ME. But only after merging both 4MB & 8MB dumps as it was not opening correctly in flash tool. Now, how do I unmerge it and flash separately to 4MB & 8MB flash chips?
There is no need to merge files, and no need to clean ME.
The autopatcher is reported to be working on T440 just fine. Use it on the 4MB dump. It will skip the NVRAM cleanup. That's fine. Then go ahead and flash it. FOLLOW THE INSTRUCTIONS!!! remove the hard disk, tape down the anti-tamper switch (if you have one).
ALSO MAKE SURE YOU ACTUALLY HAVE A SUPERVISOR PASSWORD.
The patch does not work for boot password and hard disk passwords.
It was PIA to disassemble whole laptop. The laptop hasn't been able to display anything since I flashed the patched file. Only the power key blinks. When I first flashed the patched, there were some beeps. This didn't went away despite waiting for minutes and restarting multiple times. All batteries were still removed at this point. Only gave power via adapter. It continued being blank. But then I panicked and flashed other t440p dumps on 4MB chip. This took the beep away but the display remained same i.e. blank, not even a light. Then I flashed original dump thinking it may restore my laptop, but it didn't. Now, I am cleaning ME.
I have followed instructions very carefully so far. Haven't tried hard disk thing but will it help with display? Should I just patch the 4MB and boot up without HDD when the laptop doesn't even has any display or beeps now. And only power lights up
I have supervisor password in BIOS which doesn't let me change any intel processor virtual settings. All the options are locked. It's a supervisor password and it's enabled. When ever i enter bios, it asks me for supervisor first and if i press enter, it loads basic bios with no change able option
@xaxex
CH341A programmer is known to corrupt the dump under certain circumstances, I'll say this is due to the speed of the computer being used to read/write chip (an old computer may work best, seems like programmer can not keep up and it corrupts dump when reading or corrupts chip contents when writing), but to solve this problem I suggest to use FlashROM with CH341A driver.
Get a clean ME dump for your ThinkPad T440p, once it works you can get it patched.
@xaxex My advice is if you use the ch341a programmer you should also use the Colibri 10.0.1.61 software for reading and writing back. The other software does not read/dump the eeprom correctly.
The instructions are:
Read your bios chip and create a dump file
Do it again 2-3 times and compare the files to verify integrity
Patch the dump
Write the patch to your laptop
DISCONNECT HARD DRIVE
TAPE DOWN ANTI-TAMPER SWITCH (IF PRESENT)
Boot laptop and follow the steps in the first post (or see directions by executing autopatch --howto)
WRITE ORIGINAL BIOS BACK TO THE MACHINE!
So the answer to your question "Haven't tried hard disk thing but will it help with display?" is: it's possible, but if you don't try it how can we troubleshoot?
Can anybody make patch for T570 , sizes of pach files not match as size in dump...
autopatcher alway says : Using UEFIReplace to inject 0 DXE drivers...
