  • taskmann
    • Nov 2021
    • 7
    Whad'ya Know?
    I got the OP system to work on the T460
    Just follow the instructions in detail.
    If you fail the first time, repeat the process and correct the steps.
    Don't despair!
    • grzesiek3108
      • Jun 2019
      • 10
      • Poland
      #1722
      Try this ...
      Hi, this is another spi dump?
      I had the same problem as @badurson
      "Nie mo" when i try it.
      Thats gone for now
      On clean W7 ive try and now i have syntax error.
      I saw You posted 8MB as patched, i patch 16MB so maybe i need try the little one spi ?
      Lenovo X260. Thanx for advice.
      • mferna14
        • Jun 2018
        • 1047
        I read this tread., Just want to know whether I can AutoPatch my Lenovo ThinkPad T490 (i5 8th Gen) Bin Files. It has a BIOS Password. I have attached the Original Dump from it's de-soldered BIOS Chip (W25Q256JV), if anyone can help to have the password removed, it would be great. I just noiced that there is another BIOS chip under this Board NM-B901 Rev:1.0 25Q80DVS, what is this chip for??? Will the password be on this chip??? Thanks in advance
        • klinek
          • Jun 2022
          • Poland
          #1724
          Hello
          Can someone patch my lenovo x260 Bios?
          I try script but this don't create patched file
          • cyngo
            • Jun 2015
            • 219
            • Indonesia
            #1725
            thanks. very helpful
            • taskmann
              • Nov 2021
              • 7
              This solution works for the Thinkpad 11e 3rd Gen - Type 20GB as well.
              Thanks OP
              • RAVI KARAN
                • May 2020
                • 54
                • INDIA
                #1727
                Originally posted by Maxpower3
                test
                patched this nm-b141 old bios
                • bilal1992
                  • May 2017
                  • 26
                  • algeria
                  #1728
                  Originally posted by TTR
                  Try and report back
                  steps 1 to 7 went ok . when i put back the original dump it wont turn on . now i cant read the chip i will buy another one and report back . thank you sir for the help.
                  • mferna14
                    • Jun 2018
                    • 1047
                    Any help please on this!!!
                    • mferna14
                      • Jun 2018
                      • 1047
                      Any help please on this T490!!!
                      • TTR
                        • Apr 2020
                        • 24
                        • Poland
                        #1731
                        Make sure all legs of IC are soldered solid to the pads.
                        Turn on with disconnected CMOS battery and taped anti-tamper switch and also with the disconnected hard drive.
                        • storm12t48
                          • Jun 2022
                          • belgium
                          #1732
                          Hello
                          Thank you for this patch but by applying the patch on the eeprom chip on a lenovo x270 now the pc does not even start when I turn on the power there is flashing on the power button after that nothing more thank you in advance if anyone can someone help me
                          • RAVI KARAN
                            • May 2020
                            • 54
                            • INDIA
                            #1733
                            Try this .....
                            Hello sir can you patched my bios.
                            nm-b141, x1 carbon, 7th gen cpu
                            • tadformo
                              • Jan 2022
                              Can this be used to restore a corrupt bios? X1 carbon 5th Gen (flashes on then straight off)
                              • taskmann
                                • Nov 2021
                                • 7
                                Regarding: Anti-tamper Switch
                                This is not an issue I have, but I have seen this mentioned before.
                                I googled "anti-tamper switch", but cannot any matching results, apart from switching on and off in the bios.
                                1. Where is this located on the physical computer?
                                2. Can you provide an image as an example?
                                Just need to know just in case I encounter that problem.
                                Thanks.
                                • RAVI KARAN
                                  • May 2020
                                  • 54
                                  • INDIA
                                  #1736
                                  you can use clean me bios
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12425
                                    #1737
                                    Thanks.
                                    It's look like here :
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12425
                                      #1738
                                      No, auto patcher can not repair corrupt bios. You need find Lenovo X1 carbon topic and post your corrupt bios file and serial number there.
                                      • taskmann
                                        • Nov 2021
                                        • 7
                                        @hoaca388
                                        Thank you!
                                        • bilal1992
                                          • May 2017
                                          • 26
                                          • algeria
                                          #1740
                                          the chip was bad i culdnt read it with the programmer thats how i knew it was bad . now i got new one 25q128jv and its working now , also the password has ben cleard. thank you friend , god bless you all.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
