  • AAAC
    • Jan 2020
    • 458
    • Mexico
    #1701
    @lamo
    Search the forum and find a ThinkPad T470 patched bios, this one will only be used for the unlock procedure, once unlocked you can use the Original BIOS.
    • alshalami1970
      • May 2017
      • 5
      • jordan
      #1702
      Please autopatch this file
      • TTR
        • Apr 2020
        • 24
        • Poland
        #1703
        Originally posted by TTR
        Hi.
        Thank you for this tool. I've got many successes with unlocking T470 and T460s so far.
        Today I have Lenovo T540P with 2 spi chips, after reading some posts from this thread I've desoldered the 4MB chip read it and put it in the Autopatcher and flashed it with patched file.
        After powering up the laptop I have a blank screen with 2x 5beeps.
        I flashed my original file back and everything is back to normal.
        It would be great if someone could look into my original file and try to patch it.
        Thank you
        I would like to add that I had the anti-tamper switch taped and CMOS battery disconnected.
        Later I tried to boot with a previously locked hard drive but without any success
        After patching laptop always does 2x 5 beeps and the screen remains black.
        Sorry for not editing my yesterday post, but the edit button is gone for some reason.
        • O.Szilard
          • May 2019
          • 161
          • hungary
          #1704
          Hello! I am asking for help in removing the Thinkpad T540P bios password! I read a forum, I used this: https://www.badcaps.net/forum/showth...ht=t540p+patch
          it doesn't work for me. if I do it based on the description, I write the bios, the machine turns on but does not show an image. The display is black.
          • Manjunathrawoor
            MBR
            • Mar 2021
            • 42
            • India
            #1705
            Dear all,
            Need a help on removing password - Model X-13 YOGA
            IO controller is : npce388pb0bx
            Manju
            • JTF
              • May 2022
              • México
              #1706
              Originally posted by JTF
              Hello, could someone help me with decrypt the thinkpad P17 Gen1 password or patch my file?
              I tried with autopatcher, unfortunately it doesn't generate a file.
              any help please!!!
              • Merlinox
                • Jul 2022
                • 5
                • France
                #1707
                Hello, is this thread still active ?
                The software says that my dump is corrupted or does not contain a valid dump. I Have quadruple checked it and the checksum is OK.
                winbond 25 Q 80 BL N10 1711
                P50 20EQ - S20D00 S/N PC-0NGMVH 17/08
                Lenovo
                BP500 NM-A451
                REV 1.0
                2015-11-06
                • Merlinox
                  • Jul 2022
                  • 5
                  • France
                  #1708
                  Oops, I'm new to this, I didn't archive the dump so it wasn't added. Sorry. Here it is.
                  One dumps permissions and ownership were scrambled, so I fixed them to 755 and one to 644 (default result). The result stays the same
                  • AAAC
                    • Jan 2020
                    • 458
                    • Mexico
                    #1709
                    @Merlinox
                    That error is because your chip dump is only 1MB, you need to look for other chip that may be located near uProcessor, RAM slots or EC/KBC chip.
                    • Merlinox
                      • Jul 2022
                      • 5
                      • France
                      #1710
                      Originally posted by AAAC
                      @Merlinox
                      Thank you so much for your reply, it did strike me as weird that the dump was this small.
                      This chip was hard to find. It was indeed a 20Q128 instead of a 25Q80
                      The chip is under the keyboard for lenovo P50 20EQ. You HAVE to take a part the heatsink.
                      Cheers, you saved my day !
                      Last edited by Merlinox; 07-31-2022, 01:24 PM. Reason: I didn't find the chip. And then I did.
                      • AAAC
                        • Jan 2020
                        • 458
                        • Mexico
                        #1711
                        @Merlinox
                        I’ve just sent you a PM with links of 2 pictures showing BIOS chip location on ThinkPad P50.
                        • Merlinox
                          • Jul 2022
                          • 5
                          • France
                          #1712
                          I have successfully patched the BIOS dump and flashed it. Steps 1-7 went smoothly,
                          I was told "TPM certificate changed. Turn it off." during the process.
                          @AAAC pointed out that this means that the laptop is unlocked.
                          After rebooting, the laptop posts, I can press enter to enter the setup, then the laptop beeps 4 times and shows the following messages:
                          "0271: Check date and time settings
                          0183: Bad CRC of security settings in EFI variable
                          Press F1 to enter setup"
                          Upon pressing F1 the screen stays backlit and the keyboard works (num lock toggle + fn lock toggle).
                          It stays like that indefinitely.
                          The issue persists with or without SSD plugged in.
                          What more can I do ? Did I miss a crucial step ?
                          I scrupulously proceeded with data integrity checks at every possible step.
                          edit (solved):
                          STEP 8: Restore original BIOS
                          means reflashing the first BIOS dump
                          • deep_bks
                            • Apr 2015
                            • 77
                            • india
                            #1713
                            hello dear
                            there is a password in this file LMQ-2MB 13268-1 5th gen plz help me out thanks in advance
                            • Markus1741
                              • Sep 2020
                              • 868
                              • N/A
                              #1714
                              Originally posted by deep_bks
                              hello dear
                              Try this .....
                              • deep_bks
                                • Apr 2015
                                • 77
                                • india
                                #1715
                                not power on bad luck but thnks 4 ur reply
                                • rehan
                                  • Apr 2020
                                  • 15
                                  • pakistan
                                  #1716
                                  lenovo t480 bios pwd plz nlock
                                    • 21403
                                    Use the Autopatcher at post #1 in this thread,just follow the instructions.
                                    • bilal1992
                                      • May 2017
                                      • 26
                                      • algeria
                                      #1718
                                      will someone patch this file for me please. for some reason the autopatcher is not working for me i have tried it on 3 different computers , the cmd window close right after i open it
                                      • taskmann
                                        • Nov 2021
                                        • 7
                                        Try going to the Microsoft Store from your PC and search for "python".
                                        Install the latest version available Python 3.10.
                                        I got it to work, but the autopatcher did not work for my bios.
                                        Hope it works for you.
                                        • TTR
                                          • Apr 2020
                                          • 24
                                          • Poland
                                          #1720
                                          Try and report back
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
