I found out that NeoProgrammer works better and is able to detect the chip (though the settings should be identical to BV/CV/FV).
Either this or it was because I didn't disconnect the battery when flashing before.
Now, I can get a consistent write and read.
I also extracted the BIOS file directly from Lenovo for this model (9MB, presumably with the last 7MB empty).
Unfortunately, I still get black screen and no POST.
Any thoughts?Comment
Worked perfectly fine on a Lenovo X280 ThinkPad Type 20KE that was updated to the latest (as of today) bios from Lenovo while still locked.
Bios chip was a MX25L12873F
Used CH341a programmer, no 3.3V mod.
AsProgrammer 2.1.0.13 (not sure if links are allowed, so just google it)
Chip desoldered (then resoldered, then desoldered and resoldered again
To make it easier for everyone who is more laypersons or are having difficulty in the tutorial of our friend who created the script. I created an executable based on the original script, but the user will only have to drag the BIOS file on top of the executable so that it performs the auto-patcher.
hope it helps everyone.Last edited by SMDFlea; 07-20-2022, 11:42 PM.Comment
Your tool create a new file but that file's same original file. In short it's only rename file.To make it easier for everyone who is more laypersons or are having difficulty in the tutorial of our friend who created the script. I created an executable based on the original script, but the user will only have to drag the BIOS file on top of the executable so that it performs the auto-patcher.
hope it helps everyone.Last edited by hoaca388; 07-20-2022, 08:12 PM.↵
https://www.badcaps.net/donateComment
Sorry,no more home made software can be posted without posting the source code.To make it easier for everyone who is more laypersons or are having difficulty in the tutorial of our friend who created the script. I created an executable based on the original script, but the user will only have to drag the BIOS file on top of the executable so that it performs the auto-patcher.
You MUST NOT:- Attempt to sell anything
- Post external link to paid or registration only website (incl. in archive)
- Post passworded archive
- Post unsolicited self-advertisment
- Nag people with solutions you are not willing to share
- Share private contact information
- Do business in private messages
- Seek businness opportunities
- Openly ask for donations
- Post software with malware
- Post homemade software breaking any of these rules
- Willingly post misinformation
You MUST:- Attach files directly to your post instead of linking to external websites
- Post the source code of any homemade software¹
¹. There are been multiple controversies about software developed by the community in the past. In order to avoid it happening again and support sharing the actual knowledge, source code will be required for any future software developed by the community. Source code will be highly appreciated for any existing software or for online software (SaaS type). In case of any suspicion of broken rule for existing software or online software, the software may be removed if the source code is not released.Comment
I'm afraid the board has some electrical problems from either shorts or statics. Just another brick now.I found out that NeoProgrammer works better and is able to detect the chip (though the settings should be identical to BV/CV/FV).
install python 3.8 32bit, I had the same problem and solved installing 32bit version.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
HereAttached Filesif you find these attachements useful please consider making a small donation to the site
are you able to fix it using the attached bin?Comment
hello again. need help with t470. latest bios is installed. autopatcher do patching without errors. when flashed, just blank screen, no beeps, no start. is this new protection from lenovo or what ? thanks in advance.Comment
Hi.
Thank you for this tool. I've got many successes with unlocking T470 and T460s so far.
Today I have Lenovo T540P with 2 spi chips, after reading some posts from this thread I've desoldered the 4MB chip read it and put it in the Autopatcher and flashed it with patched file.
After powering up the laptop I have a blank screen with 2x 5beeps.
I flashed my original file back and everything is back to normal.
It would be great if someone could look into my original file and try to patch it.
Thank youLast edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
well. with original locked bios, the laptop starts as usual. when flashing patched bios - laptop becomes bricked. svp presents on original bios.
i would glad to edit eeprom area of mec1653 but there're too many mess to make jtag work with this board.Last edited by lamo; 07-27-2022, 09:32 AM.Comment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by piratiHello everyone,
Product ID: RZ09-0421
Motherboard: CH580
Bios File Size: 32,768 KB
Dear Forum Readers!
!!! MY RAZER BLADE...-
11-24-2025, 05:52 PM -
- Loading...
