  • Serbentas
    • Sep 2016
    • 22
    Thanks. I tried but it shuts down at stage 2/2. Will try adjust size
    • Serbentas
      • Sep 2016
      • 22
      Same thing-shuts at stage 2/2 when patching
      • Serbentas
        • Sep 2016
        • 22
        Just here:
        • hoaca388
          Badcaps
          • Jan 2022
          • 11882
          #1584
          Originally posted by Serbentas
          Just here:
          Auto Patcher is not support for CPU gen 10th.
          • Serbentas
            • Sep 2016
            • 22
            Aaa. Is there any solution for CPU 10th or 11th gen ?
              • 21145
              There are a few exceptions. Anyway,maybe this model isn`t supported,maybe somebody else knows.It could be the EC needs programming,then use the mantenance disk to add the DMI
              • EasyMochi
                • Jun 2022
                • France
                #1587
                Thanks a lot, this script works perfectly when the instructions from the original post are followed.
                If anyone has an issue, please try reading through the posts, there's 99% chance that someone else had the same issue and fixed it. I hope someone sees this before posting! Cheers~
                • Krpys09
                  • Jun 2022
                  • Česko
                  #1588
                  I also have a Lenovo E14 and there is a password protected bios. How did you manage to get around it? Thank you.
                  • zmedia
                    • May 2018
                    • 62
                    • Algerie
                    #1589
                    hello
                    i need help patching this bios yoga370
                    utility not working for me
                    thank you
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11882
                      #1590
                      Originally posted by zmedia
                      hello
                      thank you
                      I TAKE NO RESPONSIBILITY FOR ANY DAMAGE YOU DO TO YOUR MACHINE, YOUR PETS, YOUR HOUSE, YOUR LIFE, AND THE SPACE-TIME CONTINUUM
                      Making this kind of modifications is risky and might leave you with an unusable/broken machine.
                      The script is not perfect by any means, and while I haven't bricked any hardware (yet) I can't promise that won't happen to you.
                      USE IT AT YOUR OWN RISK.
                      • zmedia
                        • May 2018
                        • 62
                        • Algerie
                        #1591
                        thnk you
                        but i dnt have display
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11882
                          #1592
                          thnk you
                          Try clean ME file
                          • Krpys09
                            • Jun 2022
                            • Česko
                            #1593
                            A have Lenovo E14, NM-C421. I tried to make a patch bios, but the image doesn't appear. Attached to the original locked bios. Can you help me please?
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #1594
                              Did you read first page of the topic?
                              Originally posted by Knucklegrumble
                              ...With some trial and error I was able to reliably patch BIOS dumps for SVP-locked Lenovo machines up to the 8th generation using the info, tools, and files provided on this forum...
                              Become a Badcaps supporter
                              Thanks to all supporters.
                              • lamo
                                • Nov 2017
                                • 40
                                • Ukraine
                                #1595
                                ok, guys. i tried different laptops with windows 7/10 and different bios images(all are known good). the autopatcher is constantly shows this:
                                Using UEFIReplace to inject 2 DXE drivers...
                                [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
                                [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
                                Looking for volumes to patch...
                                Traceback (most recent call last):
                                File "C:\lenovo_autopatcher\patch\autopatch.py", line 301, in <module>
                                patch(filename)
                                File "C:\lenovo_autopatcher\patch\autopatch.py", line 171, in patch
                                clean(patched_filename)
                                File "C:\lenovo_autopatcher\patch\autopatch.py", line 188, in clean
                                volume = load_patched_volume(p)
                                File "C:\lenovo_autopatcher\patch\autopatch.py", line 234, in load_patched_vol
                                ume
                                size = int.from_bytes(header[16:19], 'little')
                                AttributeError: type object 'int' has no attribute 'from_bytes'
                                what should i do to make this thing work properly?
                                • piernov
                                  • Jan 2016
                                  • 4437
                                  • France
                                  #1596
                                  Use Python3 not Python2.
                                  • lamo
                                    • Nov 2017
                                    • 40
                                    • Ukraine
                                    #1597
                                    ok. when i installing just python3, after typing command in terminal, the patcher says that it needs python27.dll. as far as i understand this library is used by python2, not python3.
                                    • lamo
                                      • Nov 2017
                                      • 40
                                      • Ukraine
                                      #1598
                                      allright. problem solved, copied all files to python folder. sorry for disturbance.
                                      • storm12t48
                                        • Jun 2022
                                        • belgium
                                        #1599
                                        Hello
                                        I really have trouble understanding how to use this software to erase a supervisor password on an eeprom chip on a x270 I managed to recover the bios a .bin file from my chip that I unsoldered using a decoder usb ch341 but afterwards I don't understand what I have to do next with the auto-patcher??
                                        if you could tell me the steps to follow :p
                                        • Manjunathrawoor
                                          MBR
                                          • Mar 2021
                                          • 42
                                          • India
                                          #1600
                                          Thinkpad P1 Gen3 need solution.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
