@Linux200
I suggest to read the instructions in post #1 of this thread, with the patched bios you will have to power-on the laptop and after it shows LENOVO splash screen, immediately press appropriate key to go into Setup/BIOS (press F1 key). Then follow the instructions.
If the laptop does not respond to F1 key press, then most likely it does not have a Supervisor Password set, but you can use a locked hard drive to make the patched file to work and to deactivate CompuTrace (if active).Comment
hi thanks for reply it doesn't show spalsh screen after patching bios with or without a locked drive inside@Linux200
but with original bios laptop work fine with a locked supervisor enabled ;-(
can someone send a patched bios with other methode plzComment
There are a few "t440p" bios request threads already, find one of those to post in if youre not asking for Password Removal.Comment
Already try with them on this post : https://www.badcaps.net/forum/showpo...7&postcount=12
but no positive resultComment
Try ...Already try with them on this post : https://www.badcaps.net/forum/showpo...7&postcount=12
but no positive resultAttached FilesComment
I have an Lenovo ThinkPad Yoga 260 and is password locked to bios.
I did repair this laptop after it had a failed coil.
With this model can I just reprogram the bios chip or does it require special software to remove the password? so I can boot the laptop and verify all conditions are fully working.Comment
save original , use patcher and after put back your original biosHi,
Hi All
I've read through the entire thread and researched other web pages and given this a go. Unfortunately when I try and boot after writing the patched bios nothing happens. Laptop won't turn on at all. I've tried disconnecting batteries (CMOS and main) nothing.
I've tried to write the original dump back to the chip, nothing
I've obviously done something wrong. Any advice?
Lenovo Yoga 260. Original Dump attached.
I've used CH321A with AsProgrammer
Any advice gratefully received. CheersLast edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
Write this file back maybe that helps.Hi All
Original File ME Clean Region.
Try ...Attached FilesComment
Hi, thanks for your help. I've tried writing that to the chip. Once written I've tried to verify and get the following
Verify memory...
Verification error on address: 00000019
Execution time: 00:00:00
Laptop still won't respond when I tried to boot. No beeps, no lights, nothing.
I think I may have broken something but not sure what. Could it be the bios chip is fried?
Not sure where I've gone wrong. I dumped the original 3 times and compared them, they're all fine.
I've successfully patched the original.
I've tried programming the chip with the patched bios, the original bios, other patched bios's from this forum but I get nothing...Comment
			by macabookHello everyone,
							Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
			by piratiHello everyone,
			by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
 - Loading...
