  • t440p_whisperer
    • Jul 2021
    • 5
    Originally posted by Maxpower3
    you will especially have to train yourself to unsolder the bios,
    Don't use the clip, you risk having a corrupted reading and know use the programmer
    So I’m SOL on removing the supervisor password unless I unsolder the chip? I was under the impression that I could just use it to do a BIOS dump and then flash the patched one all through the clip. Do all methods of removal require some sort of unsoldering?
    • AAAC
      • Jan 2020
      • 459
      • Mexico
      #762
      @t440p_whisperer
      I have successfully used SOP8 clip with many ThinkPad models, but I do use a EZP2010 programmer (you can get a newer EZP programmer that supports newer chips like EZP2019), that's my preferred and recommended setup, instead of risking damaging the motherboard/chip by desoldering the chip.
      • smiley60
        • Jul 2021
        • 43
        • UAE
        #763
        this program fixing the computrace problem or not
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1356
          • France
          #764
          yes, need put a password and patch
          computrace is clear after
          • daniel92
            • Jan 2015
            • 12
            • kenya
            #765
            x240 patch file anyone please help
            • shabi
              Banned
              • May 2019
              • 147
              • pakistan
              #766
              Ok
              • eugenionut26
                • Jul 2021
                • 6
                #767
                please who can help me with a patch version for a thinkpad L470, thanks
                • eugenionut26
                  • Jul 2021
                  • 6
                  #768
                  bin
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #769
                    Originally posted by eugenionut26
                    bin
                    669.6 KB then 7.88 MB, rar archive name is L470bios, but the file name within archive is t470bios...
                    Make sure you know what you're doing, so that you don't regret it in the end.
                    Become a Badcaps supporter
                    Thanks to all supporters.
                    • eugenionut26
                      • Jul 2021
                      • 6
                      #770
                      The model is L470, I was wrong when I saved it on my PC. IT WORKS PERFECT NOW. thank you very much!
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #771
                        You're welcome, I'm glad everything is fine at the end.
                        • linxz
                          • 24
                          Thank you,I read it,but I don't know how to do it.please tell more details.
                          How to get this file <your_bios_image.ext>
                          than,how to flash and replace...
                          STEP 1: Flash and replace current BIOS with the generated patch file
                          thank you so much.
                          • linxz
                            • 24
                            Hi Knucklegrumble,
                            Thank you post it,I read it,but I don't know how to do it.please tell more details.
                            thank you so much
                            • linxz
                              • 24
                              Originally Posted by CornholioGSM View Post
                              1) download and install python (i have 3.8.5)
                              2) download and unpack tool lenovo_autopatcher_0.2.zip to own folder
                              3) make dump of bios image xxxx.bin, check twice if is dump correct
                              4) put bios dump into autopatcher folder
                              5) in autopatcher folder hold shift + press right mouse -> open command line window
                              6) in CMD write "autopatch xxxx.bin" and wait for results
                              *** if you got something like python error, then is simple solution - copy all files with bios dump from autopatcher folder to python folder root...for example
                              C:\Users\vaio\AppData\Local\Programs\Python\Python 38
                              ...then again open Command line in this folder and again "autopatch xxxx.bin"
                              tested on w7
                              I got it.
                              Thank you a lot!
                              • Mazahacka92
                                • Aug 2021
                                • 5
                                • Ukraine
                                #775
                                Hello friends, lenovo yoga 11e chip 25X40CL can be patched?
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1356
                                  • France
                                  #776
                                  I don't think so, create your thread and post your dump
                                    • 22097
                                    Depends on what generation it is,and the motherboard.Post your request in one of the existing threads or start your own
                                    https://www.badcaps.net/forum/showthread.php?t=92349
                                    https://www.badcaps.net/forum/showthread.php?t=96822
                                    https://www.badcaps.net/forum/showthread.php?t=73505
                                    • Mazahacka92
                                      • Aug 2021
                                      • 5
                                      • Ukraine
                                      #778
                                      Hello friends patch please file
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1356
                                        • France
                                        #779
                                        try
                                        • Mazahacka92
                                          • Aug 2021
                                          • 5
                                          • Ukraine
                                          #780
                                          Work fine, thanks.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            Today, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
