  • mp3boy
    • Mar 2016
    • 48
    Plenty of success with other models using this patcher but the Lenovo Yoga 12 has me scratching my head...
    I successfully dumped and patched a Yoga 12 i5-4200 model, using the 4mb chip (furthest from CPU). However I'm not sure if I mixed up the boards and this one didn't actually have a password. Screen went black entering BIOS, I went through the keypresses anyway, when I flashed back to stock there was no password. Will check again tomorrow as I have one more passworded 4200 here.
    The i5-5200 model won't work in autopatcher, file "is corrupted or does not contain a valid dump." Checked with UEFITool, it loads and looks ok.
    I tried flashing the patched 4200 file onto the 5200 but it wouldn't boot. Reflashed the 5200 dump, laptop works fine (with password).
    BIOS content also seems to change on every reboot, (dump has a different md5sum) but I can always get 2 matching dumps.
    Tried again after updating to the latest BIOS (newdump.rar attached) - same issue.
    File attached if anyone could take a look please.
    • YousefT
      • Jul 2021
      • 10
      • Guinea
      #742
      Hi all, please help patch my x280 NMB521 Rev 1
      • YousefT
        • Jul 2021
        • 10
        • Guinea
        #743
        Thanks in advance
        • Locoryan
          • Jun 2017
          hello
          could somebody please patch my T480?
          • didifart
            • Jul 2021
            • FRANCE
            #745
            Successfully patched my T580.
            It has a 28Q128JVSQ eeprom (16Mb)
            I used a CH341A usb interface with colibri.
            Here's my patched bios.
            (It worked with hitting Enter key before the LENOVO LOGO)
            Thanks a lot for all your work.
            • TranTrien
              • Mar 2017
              • 7
              I am trying to open patch file with python but it disapear quickly when i dounle click on it . i have tried python 2.7 and lastest version . does anyone know how to fix it.
              Thank you
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1375
                • France
                #747
                Thank you
                try maybe
                https://www.badcaps.net/forum/showpo...postcount=1421
                • YousefT
                  • Jul 2021
                  • 10
                  • Guinea
                  #748
                  Anyone available please help patch it.
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #749
                    Here you are
                    Become a Badcaps supporter
                    Thanks to all supporters.
                    • mp3boy
                      • Mar 2016
                      • 48
                      Originally posted by Locoryan
                      hello
                      "T480original.bin is corrupted or does not contain a valid dump."
                      Try dumping the BIOS again. Make sure you have two matching files using md5sum.
                      • YousefT
                        • Jul 2021
                        • 10
                        • Guinea
                        #751
                        Originally posted by Vesko356
                        Here you are
                        Thanks Vesko and to the genius behind this Auto-patcher.
                        I appreciate a lot. It works like magic.
                        Credit goes to you all.
                        • sicelo
                          • Jul 2020
                          • Eswatini
                          #752
                          I'd like to add that it also worked perfectly for me - Thinkpad T440p
                          Thanks!!
                          • jku131
                            • Jul 2021
                            • Poland
                            #753
                            Hello, i was trying to remove supervisor password from x240 and its looks like i break something.
                            I desoldered w25q128fv and created backup and patched image using ft2232h and flashrom.
                            When i flashed patched bios and soldered chip again motherboard is turning on but there is nothing on the screen fan is working for a while and its turning off. so i desoldered bios chip again and flashed backup and its still not working? Is it possible that something broke by running patch? or is it something with soldering?
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #754
                              No
                              More likely. Or (most probably) bad programming of the chip as usual.
                              • jku131
                                • Jul 2021
                                • Poland
                                #755
                                No
                                Thanks for response, programming is good because I verified checksum after reading. What values should resistors near 25q128 have?
                                • AAAC
                                  • Jan 2020
                                  • 459
                                  • Mexico
                                  #756
                                  @jku131
                                  The resistors connected in series to chip DATA lines are 33 Ohms, PULL-UPS are 3.3k and the one for CS is 10k. Use picture as reference.
                                  • jku131
                                    • Jul 2021
                                    • Poland
                                    #757
                                    Originally posted by AAAC
                                    @jku131
                                    It looks like elements on motherboard are good. I flashed back bios backup and after running it in x240 I read it again and it changed. So its looks like motherboard is able to communicate with this, but i dont know why its not booting and modifying bios.
                                    Diff: https://pastebin.com/0d4VxNDd in backup i have "ffff ffff ffff ffff ffff ffff ffff ffff" after running it its changed. What may be causing it not working?
                                    • t440p_whisperer
                                      • Jul 2021
                                      • 5
                                      I have a T440p with a supervisor PW. I've never done any sort of BIOS modding before, I'm planning on getting one of these off Amazon. However unsure of what to do with it after, is there I thread I can read before proceeding with this tool?
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1375
                                        • France
                                        #759
                                        Patch not work for yoga 12 5200.
                                        not find solution for this, I think it's on SIO.
                                        I have many mainboard of yoga 12 5200 with PW, not had time to test
                                        • Maxpower3
                                          Bad Veteran
                                          • Feb 2018
                                          • 1375
                                          • France
                                          #760
                                          you will especially have to train yourself to unsolder the bios,
                                          Don't use the clip, you risk having a corrupted reading and know use the programmer
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • istvanszasz99
                                            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                            by istvanszasz99
                                            Product ID: RZ09-0421
                                            Motherboard: CH580
                                            Bios File Size: 32,768 KB
                                            Dear Forum Readers!
                                            !!! MY RAZER BLADE...
                                            11-24-2025, 05:52 PM
