  • ripley
    • Mar 2013
    Hi There,
    I'm reading in this forum since a long time - it's an impressive source for solutions
    Today I decided to test the autopatcher. What should I say? Works like a charm.
    Thank you Knucklegrumble!
    Tested with a Thinkpad L560 and CH341 programmer (delivered as full 3.3V version - no need to modify) running Neoprogrammer V2.20. The programm reportet the device as CH341 black.
    Tried to read eeprom in circuit with WSON clip and testclip. With 8 cycles I have 4 with identical CRC32. After also removing the BIOS battery (main battery was already off), CRC32 was identical 3 times. First flash of autopatched file went wrong. Decided to desolder chip. The problem seems to be the contact with the testclips (tried two). The file from the 3 times cycles with identical CRC32 contained the correct bios bin - lucky me
    Flashed patched file external, soldered and followed instructions.
    Desoldering, flashing original bin and the password was gone
    Kind Regards & Thank you!!
    • Sidqi Januar Riadi
      • Dec 2024
      • 35
      • INDONESIA
      #4142
      send file autopatcher please ,I always fail with the file above, it doesn't become a patched file, nothing happens
      • mike66460
        • 12
        Hello.
        This laptop has an SVP password.
        My patch attempt failed.
        After the patch, my laptop is stuck at the Lenovo logo and won't continue.
        Can you help?
        Model: Lenovo B5400
        MB: BM5 DA0BM5MB8D0 REV.D
        S/N: QB07967614​
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1398
          • France
          #4144
          Originally posted by mike66460
          Hello.
          Can you help?
          Model: Lenovo B5400
          S/N: QB07967614
          Patch not work, look on padding
          no need read kbc
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1398
            • France
            #4145
            Hello.
            Can you help?
            no need read kbc
            try
            • denis9rafael
              • Nov 2025
              • 7
              • Greece
              #4146
              Can someone please patch my supervisor locked image? The autopatcher gives the error below
              Laptop : ThinkPad L15 Gen 4
              Model : 21H4-S5QE02
              S/N : PW085EMR
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1398
                • France
                #4147
                L15 gen 4 not work with patcher
                read EC chip
                • denis9rafael
                  • Nov 2025
                  • 7
                  • Greece
                  #4148
                  read EC chip
                  Do you know where the EC chip is?
                  Is there another way to remove he supervisor password?
                  • richardrichardrichar
                    • Mar 2024
                    • Slovakia
                    #4149
                    Hello, I was scammed recenlty and bought a used X1 Tablet Gen 3. I can boot into Windows OS, but there's greyed out password option in BIOS Setup menu.
                    When I boot into bios, I see that the password is set, but I can proceed by just pressing enter. Does it mean that I'm in some user-mode, without supervisor options?
                    Can I use this patcher to remove the supervisor password by first dumping it and then modifying it? Do I need a hardware flasher, or can I do it from windows?
                    Thank you all!
                    • denis9rafael
                      • Nov 2025
                      • 7
                      • Greece
                      #4150
                      read EC chip
                      Is it the chip below? That is the one I read the bin file from.
                      • beBoss
                        Mr Mindset
                        • Mar 2023
                        • 31
                        Hi. I just patch my BIOS following all the steps, everything looks normal, I have access to all options in the BIOS, but here the problems started. I cannot boot from USB drive to install Windows, whatever I do it just go straight to the previous installed Windows. I have tried everything, like secure boot on/off, thunderbolt on/off, UEFI/Legacy, TMP on/off, "deleted" all keys where i saw options to do this in the BIOS. of course re-setted multiple times and many other options and configurations and no, doesn't boot from the usb drive. I use it almost every day so i know it works. Now I am downloading windows to put it on another drive to test it, but seems very strange to me this. Also one thing i notice in the system information it says : UEFI secure boot off, but in the security settings i have set it to enable, so something is wrong with the BIOS. Can you quick check my BIOS please for some issues? I have attached the original and the patched one with AutoPather. I think something is not okay with the BIOS.
                        The laptop is Lenovo ThinkPad X1 Yoga 3rd Gen
                        Thanks!
                        • peste
                          • 14048
                          • ROMANIA
                          #4152
                          Thanks!
                          post S/N, full name and model, motherboard model, TYPE,etc.
                          • beBoss
                            Mr Mindset
                            • Mar 2023
                            • 31
                            Hi everyone, I managed to create another USB flash drive with Windows 11 Pro, which loaded without issues and installed Windows 11 Pro.
                            I successfully updated the BIOS and everything runs smoothly.
                            Thanks for the solutions, help, and time.
                            • THANKSBUDDY
                              • Dec 2025
                              Please help. I have been trying to remove a supervisor password for the past day now. I have tried many things like different windows drivers, asprogrammer, neoprogrammer and even tried Phoenix Tools (didnt understand how to use it though). I originally patched my bios dump using lenovo_autopatcher with no luck. I just get a black screen and cant do anything. I even tried flashing random bios dumps from here. I currently have reverted to my original BIOS, thank God that worked because I thought my laptop was bricked.
                              I would greatly appreciate if someone could assist me. I tried everything I can.
                              Model: T480
                              UEFI BIOS Version: N24ET81W (1.56)
                              Embedded Controller Version: N24ht37w (1.22)
                              ME Firmware Version: 11.8.96.4657
                              Machine Type Model: 20L6S4331L
                              System-unit serial: PF1MCY3G
                              Secure boot: On
                              IC: Winbond 25Q128JVSQ
                              Thanks in advance!
                              • ali0robot
                                • Mar 2023
                                • 84
                                • N/A
                                #4155
                                Model: T480
                                Secure boot: On
                                Thanks in advance!
                                program this file then when laptop turn on press F1 give password as you like then press Enter and press two times space key, once shows TPM turn off shutdown laptop and program your original bios again, password should be removed
                                give feedback
                                • infino
                                  • Jun 2021
                                  • 10
                                  • Polska
                                  #4156
                                  Hello everyone, could you please help me patch the BIOS on my Lenovo T490s
                                  FT491/FX390 NM-B891 Rev 2.0
                                  Thx in advance
                                  I forgot to mention: I tried different BIOS versions, including "universal" ones with the Supervisor Password already removed for the T490s, but the laptop does not respond to the power button with them. Also, with the patched BIOS, the laptop emits short beeping sounds after some time. This version of the program is apparently no longer compatible with the T490s BIOS.
                                  Therefore, I still require assistance with the BIOS modification. Thank you.
                                  I removed the password by reflashing the microcontroller using Vertyanov’s programmer, and I also had to restore the laptop’s serial numbers. I managed to get everything working.
                                  • niggi
                                    • May 2016
                                    • 219
                                    • UAE
                                    #4157
                                    Try ....
                                    good working file
                                    • ripley
                                      • Mar 2013
                                      Here:
                                      • unotme
                                        • Dec 2025
                                        E590 20NB-0012GE here. I tried autopatcher, but the patched file isn't working.
                                        The original bin seems to be ok except for the pw-protection. Could anybody provide a clean file or other help please? Thank you in advance
                                        • Juan Dam
                                          • Apr 2025
                                          • uruguay
                                          #4160
                                          Hello!
                                          A have been traing with the partcher and saldly i could not unlock any notebook. I instaled python, I belive that im not lacking any steps. Currently i am working on a lenovo thinkpad x1 yoga gen 3. I would really apreciate any help or pointers
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • istvanszasz99
                                            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                            by istvanszasz99
                                            Product ID: RZ09-0421
                                            Motherboard: CH580
                                            Bios File Size: 32,768 KB
                                            Dear Forum Readers!
                                            !!! MY RAZER BLADE...
                                            11-24-2025, 05:52 PM
