 Hello Oh yes, the resistance is necessary.Comment
 Hey, can you generate for me the bios file for bypass bios password
 i already upload the informations P52S
 Thank you
 https://www.badcaps.net/forum/troubl...49#post3716449Comment
 Try this files good luck ...Hey, can you generate for me the bios file for bypass bios password
 Thank you
 https://www.badcaps.net/forum/troubl...49#post3716449Attached FilesComment
 Hi Good day I really need help I have a Lenovo V110 -15IKB and every time I enter BIOS I get a password and I don't know if it can be removed or reset as I just bought the laptop , I don't really understand anything here from page 1 so a step by step guide will be much appreciated. V110 -15IKBLast edited by ELOGS; 09-18-2025, 06:07 AM.Comment
 I can't find the chip I'm supposed to flash, not sure what I'm looking for. Could you send photos or any more details? Also, do I have to desolder an entire BGA chip to do this?
 I think RT809H is the best price/value in this category...in fact every programmer has good and bad things but to use it once or twice a year then RT809H is a good choice.
 In US you find a lot of RT809H programmers on Amazon or eBay. (ex. https://a.co/d/eUE6vcB)
 Look for RT809H not for RT809F !Comment
 OK, You asked for
 Here are the details:
 The chip you are looking for is U23 (MEC1653) and you don't need to desolder the chip !
 Look on the first picture and find all soldering points for JTAG on your MB.
 The second picture is how to connect these points to your programmer. ( don't wire #RST )
 After connecting and checking all wires start your programmer software and select MEC1653 from EC List, connect the charger and read the chip it should be 290kb.
 Save the reading to a file and check with an hexeditor ... it must be all sort of random data not all FFs or E3s or whatever single byte type...
 Erase the chip and write the file back.
 Swap back the R8796 to R8797 position before restart !
 You will lose your laptop's data such as serial number, model, etc. like:
 2200: Machine Type Invalid and Serial Number are invalid.
 2201: Machine UUID is Invalid
 2202: Product Name is invalid
 2203: System configuration is invalid.
 2204: System configuration data is invalid.
 Don't worry that can be restored from the sticker (I hope is intact...if not then ..."Houston, We have a problem").
 Use ThinkPad Config Information Update Utility v1.11 (attached) and an empty USB stick :
 -Extract and run "usbfmtpw.exe" this will format your USB and copy the files over.
 (check that the files copied after format. if not manually copy them to the root of the USB).
 -Insert to laptop and boot to USB FDD it is EFI not Legacy (USB you just created).
 -Now go to main menu and choose initialize EEPROM, this clears all keys plus UUID and now the overflow error wont happen.
 -Now go 1, then use 1 to add new info, enter C0 then Enter.
 -Now enter serial and model in long form will start with 1S so (1STTTTMMMMCCSSSSSSS like described below)
 -Enter and Key is stored.
 -If you like can add more or go back and use option 3 for a few more config details. (I set my brand name there)
 -Once all info is set go to assign UUID, and say Yes.
 (once you generate the UUID you cannot edit the serials unless you initialize and do them all over again.
 -Reboot and check bios screen your info should be there no more beeps on boot.
 Product ID: TTTT-MMMMCC
 Serial#: SS-SSSSS
 TTTT = Machine Type
 MMMM = Model Type
 CC = Country Code
 SSSSSSS = Serial Number
 ...so yours will be 1S20HGS14D00PC0PTLL4
 As a final advice before you try to flash your MEC1653:
 Check and re-check every component around the BIOS chip and try to rewrite your saved dump with the new programmer because is far,far better then the CH341A.
 Good Luck!Last edited by Stefan Steff; 09-18-2025, 09:14 AM.Comment
 This may not be super relevant, but it happened while unlocking BIOS using clip.
 Resistors next to the BIOS (33 ohms).
 I'm attaching a snippet of the schematic with the resistor code.
 It might be useful to someone.
 These are SMD resistors 0201 or 0402 33R1J(33Ohm 5%).
 0201 - ~0.6mm long.
 0402 - ~1mm long - they are a bit too big, but they can be soldered.
 Symptom is that the laptop is unresponsive.
 After applying power (with the BIOS and laptop batteries disconnected), the power button (white LED in the button) blinks three times.Comment
 I've attempted to use this for 5 password locked Lenovo M700 ThinkCentre TinyPCs, but when I attempt to run it in command line I get the message "<file> is corrupted or does not contain a valid dump. There was an error... Aborting."
 I am using a CH341a programmer because the systems are ones that I bought at auction as part of a business asset sale, and spending much more on them isn't really worth the time. I have dumped the files using both AsProgrammer and "CH341A v1.31 Free", and each verifies fine against the chip, both separately and in the other tool (i.e. a file read and saved in AsProgrammer is able to be verified against the chip in CH341A v1.31 free).
 Show this work on the M700 ThinkCentre tiny, or should I give up there?Comment
 After autopatcher patched BIOS flash the motherboard is playing a nice melody tune and does not turn the display on. Found the error code via lenovo diagnostics app. I have taped the tamper switch.
 Model: THINKPAD-P52-TYPE-20M9-20MA
 Error code: 0285
 Description: TGC-compliant functionality-related error (might be TPM initialization error)
 Can I change some "Security Chip" variable in NVRAM to false so it would not go to TPM at all?
 Any recommendations? I read and checksummed the bios after write just in case, it matched with what was sent.
 After patching, the notebook beeps 5 times, then pauses, and then beeps 5 times again. Then I see the ThinkPad logo, but the notebook freezes when trying to start the BIOS. It's a T450, and the extracted BIOS is attached.Attached FilesComment
 hi, there try this..Comment
 retry
 GIve SERIAL NUMBER OR MODEL TYPE
 Respect rules please !!!!!
 You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
- Name your thread with make, full model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
 Attached FilesLast edited by Maxpower3; 09-22-2025, 11:05 AM.Comment
			by macabookHello everyone,
							Channel: BIOS Requests ONLY!
 07-24-2025, 02:17 PM
			by piratiHello everyone,
			by jbonavitaHi, my laptop wont boot at all
 Some issues
 Things I tried
 1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
