hi try this!Attached Filesif you find these attachements useful please consider making a small donation to the site
@bojc
Most likely it does, as ThinkPad models ending with "5" have AMD processors, in which the bios firmware does not have the "Self-healing" bios protection.
So it should work for Lenovo ThinkPad E595, just make sure that you have a good bios firmware dump before starting.Comment
it didn't work for me, so i paid for the patch file and it worked, but it looks the same procedure as lenovo autopatcher@bojc
Hello friends of the Forum!
I want to thank @Knucklegrumble for shared solution. Using his tool, I have successfully removed SVP form Lenovo ThinkPad X1 Carbon Gen 2. @Knucklegrumble, great respect for your knowledge, and - once again - thank you very much!Comment
Hello all,
thanks for the tutorial and the software!
I will try to patch my T450 tomorrow.
However, I still have 2 questions.
1. do I also have to disconnect the internal battery (My Thinkpad has two batterys).
2. do I have to disconnect the CMOS battery or can I leave it on? (Want to flash the chip without unsoldering it).
Thank You!Comment
Hello, please disconnect all batteries.Hello all,
Thank You!
You don't necessarily have to separate CMOS batterie, but you can enter the BIOS better with F1.
Lenovo T450 patch already worked for me.Comment
Ok thank you. But i have a Problem.
I have the Chip w25q128fv. If i take this dump the patcher gives me follworing error:
Using UEFIReplace to inject 2 DXE drivers...
[1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
t450_3.bin is corrupted or does not contain a valid dump.
There was an error... Aborting.
If i chose W25Q128BV the Patcher bulid the file.
Can i use that?Comment
I am using the TL866 II Plus programmer with a SOP8 clip to read the BIOS chip of my Yoga 460. Although the Xgpro 10.75 software autodetects the BIOS chip correctly as MX25L12835F@SOP8 it stops reading with an ID error. The software returns "Check ID Error! Checked ID is:0x C0 00 08".
When I force it to ignore the ID error and read the chip anyway and try to read the dump in UEFITool it returns "FfsParser::parse: not a single Volume Top File is found, the image may be corrupted."
I guess, my TL866 II Plus programmer can't read the BIOS correctly. Can someone point me in the right direction to get a valid dump of my Y460 BIOS? Do I need a different programmer, software, or adapter for the clip? I hope I can use my TL866 II. I have attached a picture of my programmer setup.
Thank you in advance for your help.Attached Filesif you find these attachements useful please consider making a small donation to the site
I just finished following your instructions for a Lenovo t460 and it worked flawlessly. much thanks to everyone involved. excellent workComment
I paid for this one if it helps youAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi, you need SPI-Driver to use TL866 II with the Clip.Hello,
Thank you very much! It seems I have to order it from China, as I can't find it at any shop here in the UK
. May I ask you for a better picture of the wiring between SPI-Driver and the clip?
Would it work with a CH341a programmer and my clip straight away?
Sorry for asking all these noob questions.
Thank you for your help.Last edited by Babyface_male; 02-01-2021, 03:35 AM.Comment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by piratiHello everyone,
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
