  • mrserbest
    • Feb 2015
    • 10
    • türkiye
    #361
    Originally posted by mrserbest
    i need lenovo t460s patch please orj dump attach
    t460s patch service swich close okey
    • Markus1741
      • Sep 2020
      • 975
      • N/A
      #362
      hi try this!
      • bojc
        • Jan 2021
        • 17
        • Slovenia
        #363
        Does this solution work on Lenovo E595?
        • AAAC
          • Jan 2020
          • 459
          • Mexico
          #364
          @bojc
          Most likely it does, as ThinkPad models ending with "5" have AMD processors, in which the bios firmware does not have the "Self-healing" bios protection.
          So it should work for Lenovo ThinkPad E595, just make sure that you have a good bios firmware dump before starting.
          • bojc
            • Jan 2021
            • 17
            • Slovenia
            #365
            Originally posted by AAAC
            @bojc
            it didn't work for me, so i paid for the patch file and it worked, but it looks the same procedure as lenovo autopatcher
            • xamledyD
              • Nov 2015
              • 8
              • Poland
              #366
              Hello friends of the Forum!
              I want to thank @Knucklegrumble for shared solution. Using his tool, I have successfully removed SVP form Lenovo ThinkPad X1 Carbon Gen 2. @Knucklegrumble, great respect for your knowledge, and - once again - thank you very much!
              • Tester1212
                • Jan 2021
                Hello all,
                thanks for the tutorial and the software!
                I will try to patch my T450 tomorrow.
                However, I still have 2 questions.
                1. do I also have to disconnect the internal battery (My Thinkpad has two batterys).
                2. do I have to disconnect the CMOS battery or can I leave it on? (Want to flash the chip without unsoldering it).
                Thank You!
                • Markus1741
                  • Sep 2020
                  • 975
                  • N/A
                  #368
                  Originally posted by Tester1212
                  Hello all,
                  Thank You!
                  Hello, please disconnect all batteries.
                  You don't necessarily have to separate CMOS batterie, but you can enter the BIOS better with F1.
                  Lenovo T450 patch already worked for me.
                  • Tester1212
                    • Jan 2021
                    Ok thank you. But i have a Problem.
                    I have the Chip w25q128fv. If i take this dump the patcher gives me follworing error:
                    Using UEFIReplace to inject 2 DXE drivers...
                    [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
                    t450_3.bin is corrupted or does not contain a valid dump.
                    There was an error... Aborting.
                    If i chose W25Q128BV the Patcher bulid the file.
                    Can i use that?
                    • askaraqer
                      • Mar 2017
                      • 6
                      • Russia
                      #370
                      • Scoobywolf
                        • Jan 2021
                        • Portugal
                        #371
                        Hi.
                        I need to path this dump for my T460 to remove supervisor password. Thanks
                        • Markus1741
                          • Sep 2020
                          • 975
                          • N/A
                          #372
                          Originally posted by Scoobywolf
                          Hi.
                          hi try this!
                          • Babyface_male
                            • Jan 2021
                            #373
                            I am using the TL866 II Plus programmer with a SOP8 clip to read the BIOS chip of my Yoga 460. Although the Xgpro 10.75 software autodetects the BIOS chip correctly as MX25L12835F@SOP8 it stops reading with an ID error. The software returns "Check ID Error! Checked ID is:0x C0 00 08".
                            When I force it to ignore the ID error and read the chip anyway and try to read the dump in UEFITool it returns "FfsParser::parse: not a single Volume Top File is found, the image may be corrupted."
                            I guess, my TL866 II Plus programmer can't read the BIOS correctly. Can someone point me in the right direction to get a valid dump of my Y460 BIOS? Do I need a different programmer, software, or adapter for the clip? I hope I can use my TL866 II. I have attached a picture of my programmer setup.
                            Thank you in advance for your help.
                            • hardspank3
                              • Jan 2021
                              • 7
                              I just finished following your instructions for a Lenovo t460 and it worked flawlessly. much thanks to everyone involved. excellent work
                              • hardspank3
                                • Jan 2021
                                • 7
                                I used a CH341a programmer,
                                • Amper Men
                                  • Mar 2018
                                  • 7
                                  • mexico
                                  #376
                                  Hello can someone help me this is my backup of my bios, can somebody help me remove the password :c i would appreciate it alot thanks.
                                  • bojc
                                    • Jan 2021
                                    • 17
                                    • Slovenia
                                    #377
                                    I paid for this one if it helps you
                                    • Markus1741
                                      • Sep 2020
                                      • 975
                                      • N/A
                                      #378
                                      hi try this!
                                      • LenBios
                                        • 122
                                        • Ker
                                        #379
                                        Hi, you need SPI-Driver to use TL866 II with the Clip.
                                        • Babyface_male
                                          • Jan 2021
                                          #380
                                          Thank you very much! It seems I have to order it from China, as I can't find it at any shop here in the UK . May I ask you for a better picture of the wiring between SPI-Driver and the clip?
                                          Would it work with a CH341a programmer and my clip straight away?
                                          Sorry for asking all these noob questions.
                                          Thank you for your help.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
