Ok, so I have Lenovo Thinkpad X1 Carbon Gen 5
type: 20K4-01XUS
Serial PF-0VQQ8V
i've been searching this thread for a patched version and the only one i found the link said invalid file or something.
i've been using the patched bios posted to clear supervisor passwords on two dozen laptops now.
for some reason, autopatch fails with bad bin file every attempt. but i can dump the original bios, program the patched version (downloaded from this thread), remove the password, reprogram the original dump, then celebrate.
i was also able to use the t560 patched bios to remove the password on a p50s since it is the same motherboard
will be learning the ec technique next as i have a few x1 carbon gen 7 and 8 to unlock. i did post about nuking a p53s i'll get back to that one later
Attached Filesif you find these attachements useful please consider making a small donation to the site
i have an Lenovo Thinkpad T470s which is registered to a company.
Can somebody help me to delete this?
Model : T470s
Type: 20HG-S1V700
SN: PC-0M31J3
Thank you very much.Attached Filesif you find these attachements useful please consider making a small donation to the site
ok so never mind my post above because i found a patched version for the x1 carbon gen 5 that i could download. i'm working on gen 6 now.
i was having trouble with autopatch always having a problem with my dumps. i've been using ch341 programmer on linux. it was writing everything fine, but none of the dumps would patch.
i've been trying to figure out how to clean the me region, and had to switch back to windows, and in the process, dumped this x1 carbon gen 6 with asprogrammer. autopatcher patched it without complaining. i'm writing it to the patient right now.Comment
Could anyone help me to clear password from Thinkpad E495 Ryzen 3?
Model: Lenovo Thinkpad E495
MB: FE495 NM-C061
SN: L1HF9AD023B
I've tried autopatcher but it doesn't work with this model
Bios and EC attachedAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello you can try this new patched file ....Attached Filesif you find these attachements useful please consider making a small donation to the site
I guys,i have Lenovo T470
bios password
pls guys help meAttached Filesif you find these attachements useful please consider making a small donation to the site
PLEASE NEED UNLOCK THINKPAD P16S GEN 1
SN PF3TCCDW
TYPE 21CLAttached Filesif you find these attachements useful please consider making a small donation to the site
Need help removing BIOS password from my Lenovo T480s 20L8
Serial : PC0V3ZRN
Motherboard: ET481 NM-B471 Rev 1.0
I tried using the patched but after programming the chip. Laptop did not turn ON and when i connect charger. Power button flash 3 times and then nothing happens. I programmed back the original file but it showing the same symptoms.
I removed the chip from the motherboard.
20L8-S4S00Attached Filesif you find these attachements useful please consider making a small donation to the site
please rebuil repair and clearme
and please patch also
lenovo thinkpad e490
SN-PF-1k0mxe
NM-B911Attached Filesif you find these attachements useful please consider making a small donation to the site
I have a T480s running Windows 11, everything is working, but the BIOS is locked. So I purchased a CH341A programmer, read the chip 3 times to make sure it's right, and then patched it with the auto-patch tool. Unfortunately, the laptop refused to boot and played a melody. I had to write the original bin into the chip; otherwise, I can not use my laptop.
Would like to know why and how to patch it properly, files provided.
Model: T480s
Type: 20L8-S62100
SN: PC-11AMW1
I suggest you remove the battery, unplug the button battery, wait a minute, and then plug the button battery and main battery back. Now you should be able to post. That's how I solve similar situation today.Need help removing BIOS password from my Lenovo T480s 20L8
Serial : PC0V3ZRN
20L8-S4S00Comment
I have one Lenovo X395 (japanese) and need remove Supervisor Password.
I read my BIOS (25Q80DVSIG) but I get a error when try to patch (BIN and HEX).
Model: X395
Type: 20NM-S1PG00
SN: PC-1FBBDXAttached Filesif you find these attachements useful please consider making a small donation to the site
1 PhotoLast edited by rafaellguerra; 08-21-2025, 05:42 PM.Comment
Try with UC3 (near WWAN1 connector) and if it's W25Q128FWSIQ then it works with 1.8VComment
Thanks for your work on this.
I can't seem to get the patched BIOS to work.
I'm working on a Thinkpad T480.
S/N: PF1HZZPP (on sticker on case), System-unit S/N in BIOS is PF1LEPXM
Motherboard: NM-B501
BIOS Chip: Winbond 25Q128JVSQ
I selected the W25Q128JV chip type in AsProgrammer.
Downloaded the BIOS x 2, compared hash values and it was good.
Applied the patch.
After flashing the patched BIOS I just get the loud musical tune and a black screen. Never any words appearing.
Re-flashing the original BIOS makes it work again, but it still has the BIOS password (as expected as I never did apply a successful patched BIOS).
Any ideas? I had updated to the newest BIOS from Lenovo for the T480 before going through this. Could that be the issue? My BIOS version is: 1.55.
I've attached my original BIOS and the patched versions.
Thanks in advance for any help you can provide.Attached Filesif you find these attachements useful please consider making a small donation to the site
Write the attached BIOS content and follow this steps:Hi all,
Applied the patch.
STEP 1: Flash and replace current BIOS with the attached file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore the Lenovo_T480_ME_Clean.bin file
STEP 9: Reset BIOS settings to factory default
STEP 10: Update your BIOS to the latest versionAttached Filesif you find these attachements useful please consider making a small donation to the site
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by piratiHello everyone,
Product ID: RZ09-0421
Motherboard: CH580
Bios File Size: 32,768 KB
Dear Forum Readers!
!!! MY RAZER BLADE...-
Yesterday, 05:52 PM -
- Loading...
