 https://filetransfer.io/data-package/XXWffcco#link
 Cant upload as attachment, it doesnt allow .bin extension
 I put in link initial and patched one I did as instructed
 Its 20HQ - DX120 NM-B141Comment
 with winrar (.rar) or .ziphttps://filetransfer.io/data-package/XXWffcco#link
 Cant upload as attachment, it doesnt allow .bin extensionComment
 attached nowAttached FilesComment
 try initial patched, see open setupAttached FilesComment
 it worked, thanks man you are the king,
 im in bios settings and spv disabled, i did "load setup defaults" as well. I closed computrace from enabled to as "permanently disabled" , do you know if extra steps needed further?
 can I use laptop with this bios bin or I need to find clean default bin?
 Thanks!Comment
 use this one, see if everything works ssd /lan etc ..
 Thanks!
 you lost the windows key, if necessary ask for itComment
 Hi, I have used the search function copiously, and tried to follow a few leads in regards to getting a beep code of 0285, TCG-compliant functionality-related error (might be the TPM initialization failure). I've tried disabling TPM through powershell, tried autopatch script several times, and each time I try and boot with the modified BIOS I get a 0285 beep code. Using the dumped bios works fine. Any tips or knowhow on how to fix this? In UEFITool I found that the patched bios has a "FfsParser::checkProtectedRanges: Phoenix protected range [970000h A0000h] hash mismatch, opened image may refuse to boot" message on it, which the dumped bios does not have. I don't have the technical knowhow to calculate and patch in a new hash A0000h] hash mismatch, opened image may refuse to boot" message on it, which the dumped bios does not have. I don't have the technical knowhow to calculate and patch in a new hashComment
 https://www.badcaps.net/forum/troubl...40#post3345540Hi, I have used the search function copiously, and tried to follow a few leads in regards to getting a beep code of 0285, TCG-compliant functionality-related error (might be the TPM initialization failure). I've tried disabling TPM through powershell, tried autopatch script several times, and each time I try and boot with the modified BIOS I get a 0285 beep code. Using the dumped bios works fine. Any tips or knowhow on how to fix this? In UEFITool I found that the patched bios has a "FfsParser::checkProtectedRanges: Phoenix protected range [970000h A0000h] hash mismatch, opened image may refuse to boot" message on it, which the dumped bios does not have. I don't have the technical knowhow to calculate and patch in a new hash A0000h] hash mismatch, opened image may refuse to boot" message on it, which the dumped bios does not have. I don't have the technical knowhow to calculate and patch in a new hashComment
 Many thanksComment
 So I tried following the guide, but hit an immediate roadblock. The hash range 970000h: DA0000h doesn't match with the hash ranges in the security tab in UEFITool:
 Code:FfsParser::checkProtectedRanges: Phoenix protected range [970000h: DA0000h] hash mismatch, opened image may refuse to boot Unless I'm missing something from the tutorial?Code:Phoenix hash file found at base 00F88018h Protected ranges: RelativeOffset: 000A0000h Size: D0000h Hash: 873294B3EBBB3329BBA6ABED75392C98891C38BAF1A934FD01B45132EE4162AD RelativeOffset: 00170000h Size: 430000h Hash: F346D4820EAC0C54FF7B7D342BBEDC1773C839936B53F366B50CE7CC92DEF45B RelativeOffset: 005A0000h Size: 40000h Hash: B8B7D897008E232E13A2982BA212ED9F7DE467424B2D4BCB266A032E0A64F13A RelativeOffset: 005E0000h Size: 10000h Hash: 34669869FF876E3118FE418D5359ECB71CC02B2132BD6F68CE12C406AA4AF6F0  Comment
 [QUOTE=Maxpower3;n3465640][QUOTE=Tokeri;n3465637]
 BIOS in attachment (unmodified)
 serial number PF-1QP25J
 Type 20L6
			by macabookHello everyone,
							Channel: BIOS Requests ONLY!
 07-24-2025, 02:17 PM
			by piratiHello everyone,
			by jbonavitaHi, my laptop wont boot at all
 Some issues
 Things I tried
 1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
