    • 22293
    Originally posted by Semenovclab
    Hello friends. I have two Lenovo Thinkpad X1 Gen 3 20LE-S0HQ0B devices and their bios are encrypted.
    I tried to use the autopatch program but it didn't work. Please make a patch to reset the password.
    Sometimes after patching the original unpatched bios won`t work unless the ME firmware is cleaned,and/or the bios region is replaced with one from the bios update from lenovo support.Post the second bios bios chip (this model has 2 chips),it is needed for the ME firmware to be cleaned as both backups need joining together before FIT (flash Image Toolkit) will work. Post the laptop serial number !
    Even without eprom computer lit up and turned on, fans were spinning, lights were on but as soon as I installed flashed eprom two computers stopped responding to power "zero reaction". Now even if I solder out the eprom the laptops remain dead.
    Maybe you lost a resistor,broke a trace or something
    20LE-S0HQ0B
    Still waiting for the serial number...... https://www.badcaps.net/forum/troubl...05#post3307805
    • ar1cyber
      • Jan 2021
      • Indonesia
      #3282
      Originally posted by ar1cyber View Post
      please help me can't succes this my backup bios lock
      Lenovo X280 ThinkPad Type 20KE
      Bios chip was a MX25L12873F
      Used CH341a programmer, no 3.3V mod.
      CH341Programmer_Special Edition
      not successful, please provide another bios patch
      • floris497
        • Jul 2024
        • NL
        #3283
        Originally posted by AAAC
        @cmn.fix
        Most likely Lenovo Thinkpad X1 Yoga 4th (20QG) can not be patched as this is a 32MB BIOS, which most of the times contains a BACKUP of the BIOS and the actual "WORKING" BIOS.
        In this case the BIOS Region contains 26 Volumes, these are a few of the copies found (VolBackupBIOS:VolWorkingBIOS): 2:6, 3:7, 9:16, 10:14, 11:15, 12:13, 17:22, 18:23, 19:24, 20:25, 21:26.
        The "black screen and power button flashing" that you get is because both copies of the BIOS are being patched. If only the "working" BIOS is patched, then the ThinkPad executes the "Self-Healing" code, which copies the backup BIOS onto the "working" BIOS. If this protection could be disabled then the patch would work.
        For the moment the only option is to use an EC/KBC programmer.
        Has there been any update on this model, would it be meaningful at this moment to give it a try. Or is it still not supported with this patch?
        • jhaysgmehub
          • May 2015
          • philippines
          #3284
          Hello, I DIY'ed my friend's Lenovo T470s 20JT, after backing up the original bios I tried the autopatcher but It didn't work and no patched bin file is created so I tried my luck on downloading the shared default bin and luckily it worked. after injecting dxe drivers I have successfully removed the password but the laptop automatically shuts off after 5-10 mins and there is 5 blinks on power led. Any idea what have I done wrong?? Please help. Thank you.
          • Danmoh
            • Sep 2021
            • 61
            • Kenya
            #3285
            Lenovo Thinkpad X1 Tablet Gen 2
            Motherboard code 15218-5
            Serial Number R90QQCEF
            Kindly remove password for me.I have tried Lenovo autopatcher but the patched bios display then hangs.I have attached the locked bin.Thank you in advance
            • kabotilya
              • Feb 2023
              • 5
              • 日本
              #3286
              Try this file
              I got the same error myself, but this worked.​
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1375
                • France
                #3287
                try
                • Danmoh
                  • Sep 2021
                  • 61
                  • Kenya
                  #3288
                  Originally posted by kabotilya
                  Try this file
                  Did not power on.Thank you.
                  • kabotilya
                    • Feb 2023
                    • 5
                    • 日本
                    #3289
                    Try.
                    If you can't, run autopatcher on the BIOS dump and it will output the name and GUID of the patched location, so it may work if you use UEFITool to manually apply the patch to the original dump based on that.
                    It may also work if you rewrite the MERegion and GbE Region of the distributed patched file with those of your own dump​
                    • Bharat Shinde
                      • Jul 2024
                      • India
                      #3290
                      Hello everybody. I have Lenovo thinkpad E14 (i5 12th gen) laptop which has BIOS password/ locked condition. Is it possible to remove Supervisor Password of this model? If anybody has any information about its patch file OR password removal then pls help.
                      • wisky89
                        • Jul 2024
                        • 6
                        • VN
                        #3291
                        I am trying to remove the supervisor password of lenovo x1 carbon gen 7 model 20QE, using MX25L25635E chip, I tried using Lenovo Autopatch software but after flash the patched version, my computer cannot boot, no screen, there is only the power light signal and the beep beep beep repeatedly. Can you support me with the appropriate patch for my computer, I send the original dump and the patched version, thank you very much.
                        • peste
                          peste commented
                          Editing a comment
                          merged post..
                      • peste
                        • 13924
                        • ROMANIA
                        #3292
                        post the S/N,the motherboard model, etc.
                        • wisky89
                          • Jul 2024
                          • 6
                          • VN
                          #3293
                          Thanks for reply, motherboard model is: 20QE-S04100 and S/N is: PF-1CP4EH
                          • robinhugy
                            • Jul 2024
                            • Hungary
                            #3294
                            hello,
                            a friend bought a Lenovo M80q with bios password, but the seller dont know what the pw is
                            tried to use that tool, but i get an error message:
                            Using UEFIReplace to inject 2 DXE drivers...
                            [1/2] BootOption
                            LENOVO-M2WKT5EA.rom is corrupted or does not contain a valid dump.
                            There was an error... Aborting.
                            Bios is saved with Universal BIOS Backup ToolKit 2.0.exe (from majorgeeks)
                            Can i have a little help, how can i reset is?​
                            Tried jumper and battery, but no luck
                            Uploaded the bios file
                            • harounHD
                              • Feb 2017
                              • 50
                              • Algérie
                              #3295
                              What do you mean restore the original bios on step 8
                              Can someone explain please
                              • reeza_plus
                                • Aug 2015
                                • 61
                                • canada
                                #3296
                                ThinkPad X1 Yoga Gen 4
                                TYPE: 20QG-S39N00
                                SN: 220DW2
                                supervisor bios locked can someone help?
                                i have attached the bios and ec file please patch it thanks.
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1375
                                  • France
                                  #3297
                                  try
                                  • reeza_plus
                                    • Aug 2015
                                    • 61
                                    • canada
                                    #3298
                                    Originally posted by Maxpower3
                                    try
                                    Thank you so much
                                    Worked
                                    • ayoub ahabou
                                      • Jun 2024
                                      • Morocco
                                      #3299
                                      I hope this works. Thanks for the hard work. I was looking for a way to remove bios password for a time now on my thinkpad a475. I'll try this method when I have time.
                                      • AE Soft
                                        • Mar 2024
                                        • 10
                                        • MALAYSIA
                                        #3300
                                        Lenovo Thinkpad Yoga 11e
                                        Motherboard code 17833-1M
                                        Serial Number R90QQVWY
                                        Kindly remove password for me. I have tried Lenovo autopatcher but the patched bios no display. I have attached the locked bin. Thank you in advance
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          !!! MY RAZER BLADE...
                                          11-24-2025, 05:52 PM
